Black Hole 3.0.5.A Vu+ Uno
Ev0
Admin
Black Hole 3.0.5.A
What is new ?
Update drivers(4k models)
- Fix demux problem
[bluetoothsetup/util] update for solo4k.
[vuplus-blindscan-utils] update TT2L08/TT3L10
[Scan] Fix DVB-T2 Network Scan. (need update libdvbsi++ 0.3.8)
- Fix HDR/HLG problem
- Fix grab problem
- Fix demux problem
- Improve overall performance
- Update kernel config
- Adjust driver memory allocations
update kodiegl/chromium/directfb.
[libdvbsi++] update to 0.3.8
[dvbmediasink] update EXTRA_OECONF (solo4k, uno4k, ultimo4k, uno4kse).
update driver(zero4k)
- Fix DVB-CI problem
- Fix PLS
- Improve demux
305-png.34073
2-jpg.31506
3-jpg.31507
4-jpg.31510
7-jpg.31516
8-jpg.31509
9-jpg.31511
INFO: This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
This last feature offers the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
Thanks to plnick for help obtaining missing Ultimo4K files.
Thanks to Pedro_Newbie for Backup script.
DISCLAIMER
LICENSE (TERM OF USE)
Since I installed Blackhole 3.0.5 A when I want to install anything (***** version , edit a file , install a plugin ..) I have this problem:
* opkg_conf_load: Could not create lock file /var/lib/ipkg/lock: No space left on device.
But I have space in my Vu+ Uno
What should I do ?
What should I do ?
A good start, would be to read the rules of this board, before you get yourself banned ;)
Hi, can i install this image in flash using USB-Drive? I dont use openmultiboot. And Black Hole Speed Up settings all disable or no?
Of course: the standard is installing an image in flash; OMB is only an alternative to have many images available without chancing the main image in flash.
to large for flash install cant configure anything even set up universe without green screen and complain about no free space
Just curious... I wiped my vu+ uno and have no ability to do these openmultiboot settings from the GUI. Do I need to install an old version of BH to do this or is it possible from scratch?
No, it's better to install always a recent image in flash, to avoid problems. My advice is to install OBH in flash ('cause it's lighter) and then (almost) whatever in multiboot.
