Black Hole 3.0.5.F Vu+ Duo2
Ev0
Admin
Black Hole 3.0.5.F​
What is new ?
Fix harddisk bug
update drivers(uno4k, uno4kse, ultimo4k)
- Fix DiSEqC timing
- Support Dual DVB-S2X FBC tuner(needs E2 update)
update drivers(solo4k, uno4k, uno4kse)
- Fix media playback(24Fps)
Fix default recording path and usb recording.
[dvbapp] update.
[autofs] remove sync option for broken recording issue for ext4 filesystem.
[udev] fix automount
305-png.34073
2-jpg.31506
3-jpg.31507
4-jpg.31510
7-jpg.31516
8-jpg.31509
9-jpg.31511
INFO: This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
This last feature offers the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
Thanks to plnick for help obtaining missing Ultimo4K files.
Thanks to Pedro_Newbie for Backup script.
DISCLAIMER
LICENSE (TERM OF USE)
thanks Evo . so in version D is no updates for duo2
3.0.5.D was never released it was for internal testing only, but some people decided to online update and found issues.
But there were no specific updates for Duo2
thanks Evo . will wait to update the box until its fixed regards the vuplus error
need to add 8.8.8.8 to secondary DNS to get it to work to connect to other devices. This an OLD problem
webinterface I just cant connect to I have old port and old ip. I just updated from 3.03 to this latest version any idea why? I keep getting message your connection is not private
