Black Hole 3.0.5.I Vu+ Solo2 + USB DVB-T2 Tuner
Solved,
After you update the Software to 3.0.5.1 then power off and remove USB key.
Power on the VU Solo 2 with the USB DVB-T2 tuner inserted in the Top Rear USB PORT
Wait for the receiver to power and follow the Wizard to setup the receiver, once the receiver is setup do not do a channel scan, just press menu and scoll to FACTORY RESET and click OK to Factory Reset the receiver.
Once the receiver boots up again use the WIzard to set up the VU Solo 2 and then do an Auto Scan , All terrestrail and Satellite channels will be loaded and are viewable.
