Black Hole 3.0.5.I Vu+ SoloSE / SoloSE V2
Ev0
Admin
Black Hole 3.0.5.I
What is new ?
Fix online update bug with some boxes
305-png.34073
2-jpg.31506
3-jpg.31507
4-jpg.31510
7-jpg.31516
8-jpg.31509
9-jpg.31511
INFO: This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
This last feature offers the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
Thanks to plnick for help obtaining missing Ultimo4K files.
Thanks to Pedro_Newbie for Backup script.
DISCLAIMER
LICENSE (TERM OF USE)
  • BlackHole-3.0.5-vusolose_usb_release_20180306_17a33d3.zip
zagoracity
hello guys.a network error has occured.please check your network connection message on youtube.my STB is VU+ zero latest BH image Black Hole 3.0.5.I
amr gadou
How to change the language of the keyboard to the Arabic language knowing that the language of the keyboard supports only English and German only Is there a solution to add Arabic to the keyboard
vamas
Have just installed software 3.0.5.1 oln my vu solo se and started all from scratch. set limits etc. When I try to use satfinder on positioner settings, it does not allow me to put in transponder number and other details and keeps going in green screen. All save sat are lost etc. I have tried downloading file from 3 different sites including of course here first and keep getting the same problem.
Any suggestions please?
thanks
Mick12334
Moderator
Are you loading anything, including your old channel list, prior to setting up your system?
Have you checked your cables, for sign of damage, and checked your LNB?
