Black Hole 3.0.5 Vu+ Duo
Ev0
Admin
Black Hole 3.0.5​
What is new ?​
- Update and fix CrossEPG
- Fix Timer recording bug
- Fix USB recording
- Add Overlayfs for new kernel (Uno4KSE, Zero4K)
- Add Uno4KSE support
- Add Zero4K support (beta)
- Add VP9 Support (Ultimo4K, Uno4KSE, Uno4K, Zero4K)
- Add Dvb-S2X support (Zero4K)
- Add Multistream/PLS support (Zero4K)
- Add Blindscan support (Zero4K)
- Update Drivers (Ultimo4K, Uno4KSE, Uno4K, Solo4K, Zero4K, Duo2, SoloSE, Solo2, Zero)​
305-png.34073
2-jpg.31506
3-jpg.31507
4-jpg.31510
7-jpg.31516
8-jpg.31509
9-jpg.31511
INFO: This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
This last feature offers the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
Thanks to plnick for help obtaining missing Ultimo4K files.
Thanks to Pedro_Newbie for Backup script.
DISCLAIMER
LICENSE (TERM OF USE)
thanks for this great work!
Did I understand right, that it does not work with mediasat? Sorry I am a newbie...
I am being really stupid here. I have a Solo Pro DVB-S2 box which has a Vu plus installed (and the blackhole panel, it says magic box). Basically, I got this box and have been told that I need a subscription (to continue watching channels). Wonder if I can do it myself. Do you have any instructions as to how I can reactivate it or perhaps flash it and start fresh.
Your box is a clone, we don't support clones on this board.
Also you are asking about watching channels illegally, again not supported on this board.
However you would know this, if you had read the rules of this board, that you agreed to when you signed up on here.
So congratulations on your 1st post, and earning yourself a 7 day ban.
I suggest you take the time to read and learn the rules if you plan to stay on here.
Hi,
Thank you.
I am new to this forum and I have just acquired a vu + duo used. I installed this version but there is only 3 MB of free on the flash of the box. Is there a lighter version or should I go back to an older version.
Thank you for your help.
Sorry for my bad English, i use Google translation :)
Hi,
Thank you.
Try OBH this is very similar image to BH.
Other way ; is have OBh in flash and next on molltiboot used BH.
In Bh is good setup swap
