Black Hole 3.0.5 Vu+ Duo2
Ev0
Admin
Black Hole 3.0.5​
What is new ?​
- Update and fix CrossEPG
- Fix Timer recording bug
- Fix USB recording
- Add Overlayfs for new kernel (Uno4KSE, Zero4K)
- Add Uno4KSE support
- Add Zero4K support (beta)
- Add VP9 Support (Ultimo4K, Uno4KSE, Uno4K, Zero4K)
- Add Dvb-S2X support (Zero4K)
- Add Multistream/PLS support (Zero4K)
- Add Blindscan support (Zero4K)
- Update Drivers (Ultimo4K, Uno4KSE, Uno4K, Solo4K, Zero4K, Duo2, SoloSE, Solo2, Zero)​
305-png.34073
2-jpg.31506
3-jpg.31507
4-jpg.31510
7-jpg.31516
8-jpg.31509
9-jpg.31511
INFO: This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
This last feature offers the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
Thanks to plnick for help obtaining missing Ultimo4K files.
Thanks to Pedro_Newbie for Backup script.
DISCLAIMER
LICENSE (TERM OF USE)
Personal backup is still not working as expected.
Since BH3.0.2d the "Personal backup" is only partly working.
Network settings, Lcd4config and manually added addons/plugins is restored ok.
Tuner setup, Channellist, Cec, User settings, "Audio languages setup" and "UI pos setup" is not restored.
Best regards
BH3.0.5 "Personal backup" is still not working as expected.
Tested again from BH3.0.4d to BH3.0.5
Best regards
HI,
Currently I have installed soft 3.0.4 D and I'm trying to update by the automatic software update on the box but it doesn't see any new soft avalible or I'm doing something wrong. How can I update to this new soft? wich option should I use?
HI,
you have to do a clean installation, you have to install it all again so that the image works properly
I just updated image from oldest 2.7
I wanted to try if audio AC3 codec problem on AVI and MKV files works OK but unfortunately it continues.
Do you know if it will be possible to solve this issue for incoming versions?
It's a pity, I will have to downgrade my VU+ duo2 to 2.7 again.
Anyway thak you very much for your excellent job on this great image.
Regards,
Koleman
