Black Hole 3.0.5 Vu+ Uno
Ev0
Admin
Black Hole 3.0.5​
What is new ?​
- Update and fix CrossEPG
- Fix Timer recording bug
- Fix USB recording
- Add Overlayfs for new kernel (Uno4KSE, Zero4K)
- Add Uno4KSE support
- Add Zero4K support (beta)
- Add VP9 Support (Ultimo4K, Uno4KSE, Uno4K, Zero4K)
- Add Dvb-S2X support (Zero4K)
- Add Multistream/PLS support (Zero4K)
- Add Blindscan support (Zero4K)
- Update Drivers (Ultimo4K, Uno4KSE, Uno4K, Solo4K, Zero4K, Duo2, SoloSE, Solo2, Zero)​
305-png.34073
2-jpg.31506
3-jpg.31507
4-jpg.31510
7-jpg.31516
8-jpg.31509
9-jpg.31511
INFO: This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
This last feature offers the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
Thanks to plnick for help obtaining missing Ultimo4K files.
Thanks to Pedro_Newbie for Backup script.
DISCLAIMER
LICENSE (TERM OF USE)
My friends... Could you explain me, why can't I see Youtube Video here? Not YouTubePlayer, not others, but the standard Youtube Video like on TVs. I remember it was there, on older 2.* BH versions...
No, unfortunately... I do see it on my VuSolo 2, but not on VuUno. I tried to install it through plugins and "SpeedUp BH", but no luck. There are so-called "YouTube Git", "MyTube", "YouTubePlayer", but not the standard Youtube Video which can be controlled with mobile app.
If this application is missing in the default image installation, can anyone guide me through the steps of adding it back? Or probably it is there but somehow went away from the menu?
May be developers can include it to the default installation?
Hello. Thank you for the great work! Question: Is it possible to install this image not through openmultiboot? Simply always put your images only through a flash drive. Thank you
hello, good job for the update.
i got 3.0.3 Q but i don't see new update on the menu, its possible ?
okay thanks for answer
if i save a backup my 3.0.3 Q version and i install the new one 3.0.5, i can backup the 3.0.3 Q settings on the new one version ?
You can not restore the settings from Bh 3.0.3 to BlackHole 3.0.5.
Altough, you can download your image settings ( channel services ), by using a settings editor too like ( dreamset, dreamboxedit, E-channelizer, etc ... ) an then upload this settings to the new image.
Hi, I've installed this new image and I can't instal ******* or *****..this message mpprrs when I've tried : could not create lock file/var/lib/opkg/lock: no space left on device..any tip? thank you in advance
My tip is you take the next 7 days to read the rules of this board (the ones you agreed to when you signed up on here).
How is the process to install this image? The vu+ UNO not have space so not have, exist any tutorial to do it?
I do the next steps from new installation of this image and always have green screen with crash error:
1. Select HDMI
2. Select 1080i,
3. Select input port Not
4. Select language spanish, OK to next step
5. use the wizard to set up basic features, OK
6. Configuration Mode not configured, OK
7. enable the parental control feature on your STB? No, OK
8. If you want to connect your botx to the internet ... Press OK, OK, Use Interface yes, use DHCP yes and Use Manual dns-nameserver no, press OK
9. In the screen Welcome you setopbox is now ready to use pleas press OK, OK
10. In Screen Black Hole Speed Up for default all is Disable, I not change any becouse the device not have space to can enable and save any plugins, so I press red button to Save
11. The next screen is te (TV) Boutquets that is empty becouse not have space to download any default, now I press exit botton to go to the main screen
I have internal hard disk where I had with previous version 3.0.3 San universe, so then I press menu button to go to Teleportation and press OK, the screen show "Sorry no space available to expand your Universe, to enable Paralle dimensions you need a dadicated USB stick. Instructions: 1) Format you Usb stick-click on blue -> blue -> Usb Format Wizard and Map the newly formatted stick to "universe" click on blue -> blue -> Devices manager
12 I tried to do that but then I see green screen so I have to do of this way:
Button Menu - Black Hole Apps - USB format wizard - Button red but is impossible, my internal disk not is a option. I tried also from istall multiboot in the step 10 Screen Black Hole Speed I tried installing multiboot but was impossible too, I had the next error:
Collected errors:
*opkg_conf_load: Could not create lock file /var/lib/opkg/lock: No space left on device.
I tried using a pen drive formatting but I had other green screen and after green screen always have to start the wizard again...
Only with reboot the vu+uno I see the green button.
So all that I try fail, I am sure the information to do this probably is in this forum but I not found can you tell me link wich the full steps to configure?
It would be very useful in the images of vuplus models that have this problem a link to how the installation should be done.
In my case I have a hard drive so as not to depend on an external USB disk.
Regards
Hi there,
Same issue here,
vu+ uno
Because i could't install any plugins due to lack of space ("no space left on device") i was going to try blackhole parallel universes as well, but before i got that far i had to map the usb stick to "universe" resulting in a green screen.
i tried several versions of 3.*.*. all with the same result
Now i went back to 2.1.7 and all works like a charm.
Is there a way to increase free space on flash during installation or directly after installing the 3.x.x. image?
Any help would be appreciated
