Black Hole 3.0.6 Vu+ Zero4K
Ev0
Admin
Black Hole 3.0.6
What is new ?
  • Completely re-written the BH EPG system.
  • Added EPGImport support
  • Added FreeSat, Netmed, ViaSat and Virgin EPG
  • Updated Sky EPG
  • Added options to Load-Save-Delete epg.dat
  • Updated CrossEPG
  • Fixed DVB Subtitles issue on some channels
  • Swapped Buttons around in BH panels to match layout of other images
  • Various Skin updates from MX10
1-png.39754
2-jpg.39741
3-jpg.39742
4-jpg.39743
7-jpg.39746
8-jpg.39747
9-jpg.39748
10-jpg.39749
11-jpg.39750
12-jpg.39751
Please Note:
Due to limited resources some end of life models will no longer be supported from BH 3.0.6 onwards. If you want to use BH with these receivers please use version 3.0.5
The following is a list of the receivers that will not be supported in version 3.0.6 onwards:
Vu+ Zero
Vu+ Ultimo
Vu+ Uno
Vu+Duo
Vu+ Solo
This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- CrossEPG supported
- EPG Import supported
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
Thanks to plnick for help obtaining missing Ultimo4K files.
Thanks to Pedro_Newbie for Backup script.
DISCLAIMER
LICENSE (TERM OF USE)
  • BlackHole-3.0.6-vuzero4k_usb_release_20181003_578734e.zip
wawa16
Hello
Perfect ....
My problem has been solved with this release
My server ….. Work 100%
Previous version 3.0.5.I .... I suffered and did not work my server ….. ( …... )
wawa16
What's Kodi version ?
To update Kodi when a new version is released use this commands via telnet
sudo apt-get update
sudo apt-get upgrade
Note: In some cases where additional packages are required, Kodi will fail to upgrade when using the upgrade commands as above. To install additional packages use the command below
sudo apt-get dist-upgrade
Adoniss
No readings of SNR in dB in Black Hole
because there is no VU + original coding for it.
Everything else is a question of driver and VU + coding.
Thanks for prompt reply
Black hole should work on this because signal strenghs is always measure in db and if any receiver or any firmware dont support such basic function is a peace of crash
Matrix10
I have different opinion.
How many users understand what's dB ?
Not only those users, already 70% of technicians do not know the definition of strength expressed in decibels.(dB microvolt ,dB miliwatt e.t.c)
They all understand the percentages.
Besides, it's just a relative measurement. Box is not a precision instrument.
The decibel (symbol: dB) is a unit of measurement used to express the ratio of one value of a physical property to another on a logarithmic scale. It can be used to express a change in value (e.g., +1 dB or −1 dB) or an absolute value. In the latter case, it expresses the ratio of a value to a reference value; when used in this way, the decibel symbol should be appended with a suffix that indicates the reference value, or some other property. For example, if the reference value is 1 volt, then the suffix is "V" (e.g., "20 dBV"), and if the reference value is one milliwatt, then the suffix is "m" (e.g., "20 dBm").
So the question is what is the signal level if the display is at 12 decibels.
Who knows?
Standard Users ?
Is decibel a correct name for SNR ???
what is the reference value ?
Adoniss
Who knows?
Standard Users ?
My dear fellow ,please don't try to defend any defect or deficiency merely saying people dont know or are not acquainted to.
Liters,kilo meters ,feet etc , everything is measured in unit's and dB is commonly used to measure signal strength and other than Chinese cheqp receiver's all other linux boxes displays signal strength in db as % is not a unit to measure signal quality and even vu plus various models shows videos with minimum % of signal because itsi not a unit to measure and % of signal varies with change of receiver but in dB valus of signals remain the same.
Vupluse zero 4k displays video on zero % too but solo 4k on 30% to 40%
If black hole or this receiver not display signal strength that means teams need to work on development of software and inception of good hardware in future model's as vupluse is continuously luanching poorly hardware receiver's in market since last few years
Matrix10
You are confusing two things
measurement in decibels and percentages
and Zero 4k problem with measurement.
That has nothing to do with each other.
Zero 4K measurements can only be fixed by VU + because they have hardware information
and software (drivers)
It can not be solved by any team that is known to me.
The teams do not have access to the above.
On the other hand, despite this lack of VU + Zero 4K is a fantastic receiver
with the best tuner of all other VU + receivers i have test i think all of them.
It's not clear to me why you're buying something
for what you have so bad opinion about.
Buy these Chinese receivers they are certainly better.
Of course not.
Comparing quality is one and the visual SNR , second problem.
Since I've been in electronics for more than 30 years, I know what I'm talking about.
For this money this is a good and sensitive receiver.
I think we have to end this discussion.
Makes no sense.
You got the answer to the question asked.
Everyone buys what suits him.
AlexWilMac
Moderator
This obsession about measurement is frankly RIDICOULUS.
But it's ridiculous particularly because, as Matrix said and as said thousands of times, decoders ARE NOT ABLE TO GIVE YOU A STANDARD, ABSOLUTE VALUE. Each box has its own values and you can just and only compare two transponder by teh SAME BOX, not two different boxes' values.
What matters is: can you watch a channel or not? Everything else is waste of words.
