Black Hole 3.0.7 Vu+ Duo4K
Ev0
Admin
Black Hole 3.0.7
What is new ?
  • Many bug fixes
  • Added new feature to let you know when an online update is avaliable
  • Changed default Skin to MX Black Sea
  • New Bootlogo
  • New default Spinner
  • Improved Wi-Fi setup
  • Added Duo4K support
  • Reintroduced Support for Solo, Duo, Uno, Ultimo and Zero
This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- CrossEPG supported
- EPG Import supported
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
Thanks to Pedro_Newbie for Backup script.
DISCLAIMER
LICENSE (TERM OF USE)
  • BlackHole-3.0.7-vuduo4k_usb_release_20181203_54f28d9.zip
stazeb
I found sollution:
1. In Tuner Configuration:
Configuration mode: enabled
Used service scan type: Provider
Provider to scan: ZIGGO Zuid (NL)
2. In Manual Scan: select
Type of scan: complete
Network scan: yes
Clear before scan: yes
Only Free scan: no
4. Press OK for scan
Result 290 channels.
