Black Hole 3.0.7 Vu+ SoloSE and SoloSE V2
Ev0
Admin
Black Hole 3.0.7​
What is new ?
  • Many bug fixes
  • Added new feature to let you know when an online update is avaliable
  • Changed default Skin to MX Black Sea
  • New Bootlogo
  • New default Spinner
  • Improved Wi-Fi setup
  • Added Duo4K support
  • Reintroduced Support for Solo, Duo, Uno, Ultimo and Zero
1-jpg.40798
2-jpg.40789
3-jpg.40790
4-jpg.40791
5-jpg.40792
6-jpg.40793
8-jpg.40795
9-jpg.40796
10-jpg.40797
This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- CrossEPG supported
- EPG Import supported
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
Thanks to Pedro_Newbie for Backup script.
DISCLAIMER
LICENSE (TERM OF USE)
Hello.
There is a problem with Time & Timezone in this image.
When I choose (GMT+01:00) Amsterdam, Berlin, Bern, Rome, Vienna
I get correct time - really +1 (09:13)
But when I choose +2 or +3, I get wrong time
It should be 10:20 for Timezome +2
and 11:21 for Timezone +3
but I get 8:20-8:21.
Please, fix it.
Try this file and let me know if it works any better.
Unzip it and put into /etc/tuxbox (backup the original first, just incase).
Then reboot the box
  • Like
Reactions: azl
Then reboot the box
Thank you very much. It works. Now everything OK with time.
  • Like
Reactions: Ev0
Hello.
After updating to 3.0.7 I get hangs (freezes) on my receiver every day. I even can't turn receiver on when it is in stand by. I press power button on the remote control and nothing happens. At this time I also can't open OpenWebif on my PC.
After some time (approximately 1-2 minutes) everything normalizes - receiver turns on, OpenWebif opens.
It never happened earlier.
Today I got online update, but it didn't fix this problem.
Hangs problem disappeared, thanks. But now every day I get a message that online update is available. And every day I get the same 3 packages. I think that something wrong with online updates.
