1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Black Hole 3.0.8 Vu+ Duo
Discussion in 'Vu+ Duo Black Hole Images' started by Ev0, Dec 24, 2018.
  1. Ev0
    Ev0 Administrator
    3,080
    MERRY CHRISTMAS FROM THE BH TEAM
    Black Hole 3.0.8
    What is new ?
    • Many bug fixes
    • Added Serviceapp with Exteplayer3
    • New Bootlogo
    • Updated Mediatree to support more USB tuners
    • Updated Duo4K Drivers
    *** DUE TO THE LIMITED FLASH SPACE, WE RECOMMEND THAT THIS IMAGE IS ONLY USED IN OMB (OpenMultiboot) WITH THIS MODEL ***
    This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
    - Integrated OpenEpg
    - CrossEPG supported
    - EPG Import supported
    Yellow button = Audio menu
    Addons
    Infobar / OSD
    Analog Clock Gui
    Channel orbital location
    Signal SNR, BER
    Infobar picons
    Blue Panel
    Extra Settings
    Black Hole Speed Up
    Devices Manager
    Usb Format Wizard
    Telnet Panel ( Telnet Panel)
    FTP Panel ( FTP Panel)
    UPnP Client Djmount
    UpnP Server Minidlna
    Pcsc Panel
    Tuner Server
    Network Browse & Mountpoints
    Info Panel
    3 - About (info)
    Memory (Memory)
    Space (capacity)
    CPU (processor)
    Process (process)
    EPG Panel
    Green Panel
    Addons (added)
    Online Feeds Settings update
    Red Panel
    BlackHole
    Avalon
    Chaos
    Ghost
    ServiceApp and Exteplayer3 are both external plugins, and are not part of the BH image, therefore any users that do not want / need to use these plugins, can remove them via the BH SpeedUp panel.
    Credits:
    Thanks to MX3L for ServiceApp https://github.com/mx3L/serviceapp/tree/develop
    Thanks to SamSamSam for Exteplayer3 https://github.com/e2iplayer/exteplayer3
    Thanks to dpeddi for patching ServiceApp and Exteplayer3 to work on BH.
    Thanks to Pedro_Newbie for Backup script.
    DISCLAIMER
    LICENSE (TERM OF USE)
    saeid0919 and Foreman like this.
  2. Ev0
    Ev0 Administrator
    3,080
    BH 3.0.8 onwards includes ServiceApp and Exteplayer3 which gives improved media playback / streaming performance.
    It is pre-installed in all boxes, except Gen1 Solo, Duo, Uno, Ultimo and Zero, so you will have to enable it from the BH SpeedUp menu on those boxes.
    To use it with IPTV, you can either leave the ServiceApp settings as default and in your IPTV lists, just change the #SERVICE 1:0:1: or #SERVICE 4097:01: to #SERVICE 5002:0:1:
    Doing this, Exteplayer3 will only be used on your IPTV streams.
    Or you can change the default setting of Enigma2 playback system in the ServiceApp menu from Original to Exteplayer3.
    Note: that you can not record IPTV streams if you are using Exteplayer3 (however Enigma2 isn't reliable when recording IPTV anyway).
    Changing the setting in the ServiceApp menu, means that the image will no longer use the built in Mediaplayer (linked to Gstreamer) and will use ExtePlayer3 for all media playback for IPTV and streaming aswell as any movies / recordings on your hdd, doing this you won't need to convert your IPTV lists to #SERVICE 5002:0:1:
    But please note, that ServiceApp isn't perfect, it does not know the difference between Mpeg1 and Mpeg2 files, therefore it will report any Mpeg2 as Mpeg1 and the Zerok4K and Duo4K do not support Mpeg1, so even though these files are really Mpeg2 because ServiceApp reports them as Mpeg1 you will only get Audio on these files.
    All other Vu+ boxes support Mpeg1 so it's not too much of an issue.
    Also note that Subtitles will not work and trying to use Subtitles with Exteplayer3 may cause Enigma2 to crash, this is a known issue, and it is not something we can fix.
    dizz707 likes this.
  3. razidue
    razidue Vu+ Newbie
    2
    thank you for all your support
  4. Dashisha33
    Dashisha33 Vu+ Newbie
    1
    Thank. Thank youagain
