Black Hole 3.0.8 Vu+ SoloSE and SoloSE V2
Ev0
Admin
MERRY CHRISTMAS FROM THE BH TEAM
Black Hole 3.0.8
What is new ?
  • Many bug fixes
  • Added Serviceapp with Exteplayer3
  • New Bootlogo
  • Updated Mediatree to support more USB tuners
  • Updated Duo4K Drivers
This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- CrossEPG supported
- EPG Import supported
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
ServiceApp and Exteplayer3 are both external plugins, and are not part of the BH image, therefore any users that do not want / need to use these plugins, can remove them via the BH SpeedUp panel.
Credits:
Thanks to MX3L for ServiceApp https://github.com/mx3L/serviceapp/tree/develop
Thanks to SamSamSam for Exteplayer3 https://github.com/e2iplayer/exteplayer3
Thanks to dpeddi for patching ServiceApp and Exteplayer3 to work on BH.
Thanks to Pedro_Newbie for Backup script.
DISCLAIMER
LICENSE (TERM OF USE)
BH 3.0.8 onwards includes ServiceApp and Exteplayer3 which gives improved media playback / streaming performance.
It is pre-installed in all boxes, except Gen1 Solo, Duo, Uno, Ultimo and Zero, so you will have to enable it from the BH SpeedUp menu on those boxes.
To use it with IPTV, you can either leave the ServiceApp settings as default and in your IPTV lists, just change the #SERVICE 1:0:1: or #SERVICE 4097:01: to #SERVICE 5002:0:1:
Doing this, Exteplayer3 will only be used on your IPTV streams.
Or you can change the default setting of Enigma2 playback system in the ServiceApp menu from Original to Exteplayer3.
Note: that you can not record IPTV streams if you are using Exteplayer3 (however Enigma2 isn't reliable when recording IPTV anyway).
Changing the setting in the ServiceApp menu, means that the image will no longer use the built in Mediaplayer (linked to Gstreamer) and will use ExtePlayer3 for all media playback for IPTV and streaming aswell as any movies / recordings on your hdd, doing this you won't need to convert your IPTV lists to #SERVICE 5002:0:1:
But please note, that ServiceApp isn't perfect, it does not know the difference between Mpeg1 and Mpeg2 files, therefore it will report any Mpeg2 as Mpeg1 and the Zerok4K and Duo4K do not support Mpeg1, so even though these files are really Mpeg2 because ServiceApp reports them as Mpeg1 you will only get Audio on these files.
All other Vu+ boxes support Mpeg1 so it's not too much of an issue.
Also note that Subtitles will not work and trying to use Subtitles with Exteplayer3 may cause Enigma2 to crash, this is a known issue, and it is not something we can fix.
Hi Guys,
So, if I have understood well, installing this new version 3.0.8 on a Vu+ SoloSE (no 4K year 2016) it will "become 4K".
If not, thanks as usual for the great job!
