Black Hole 3.0.8 Vu+ Ultimo4K
Ev0
Admin
MERRY CHRISTMAS FROM THE BH TEAM
Black Hole 3.0.8
What is new ?
  • Many bug fixes
  • Added Serviceapp with Exteplayer3
  • New Bootlogo
  • Updated Mediatree to support more USB tuners
  • Updated Duo4K Drivers
This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- CrossEPG supported
- EPG Import supported
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
ServiceApp and Exteplayer3 are both external plugins, and are not part of the BH image, therefore any users that do not want / need to use these plugins, can remove them via the BH SpeedUp panel.
Credits:
Thanks to MX3L for ServiceApp https://github.com/mx3L/serviceapp/tree/develop
Thanks to SamSamSam for Exteplayer3 https://github.com/e2iplayer/exteplayer3
Thanks to dpeddi for patching ServiceApp and Exteplayer3 to work on BH.
Thanks to Pedro_Newbie for Backup script.
DISCLAIMER
LICENSE (TERM OF USE)
  • BlackHole-3.0.8-vuultimo4k_usb_release_20181224_aa3715e.zip
Ev0
Admin
BH 3.0.8 onwards includes ServiceApp and Exteplayer3 which gives improved media playback / streaming performance.
It is pre-installed in all boxes, except Gen1 Solo, Duo, Uno, Ultimo and Zero, so you will have to enable it from the BH SpeedUp menu on those boxes.
To use it with IPTV, you can either leave the ServiceApp settings as default and in your IPTV lists, just change the #SERVICE 1:0:1: or #SERVICE 4097:01: to #SERVICE 5002:0:1:
Doing this, Exteplayer3 will only be used on your IPTV streams.
Or you can change the default setting of Enigma2 playback system in the ServiceApp menu from Original to Exteplayer3.
Note: that you can not record IPTV streams if you are using Exteplayer3 (however Enigma2 isn't reliable when recording IPTV anyway).
Changing the setting in the ServiceApp menu, means that the image will no longer use the built in Mediaplayer (linked to Gstreamer) and will use ExtePlayer3 for all media playback for IPTV and streaming aswell as any movies / recordings on your hdd, doing this you won't need to convert your IPTV lists to #SERVICE 5002:0:1:
But please note, that ServiceApp isn't perfect, it does not know the difference between Mpeg1 and Mpeg2 files, therefore it will report any Mpeg2 as Mpeg1 and the Zerok4K and Duo4K do not support Mpeg1, so even though these files are really Mpeg2 because ServiceApp reports them as Mpeg1 you will only get Audio on these files.
All other Vu+ boxes support Mpeg1 so it's not too much of an issue.
Also note that Subtitles will not work and trying to use Subtitles with Exteplayer3 may cause Enigma2 to crash, this is a known issue, and it is not something we can fix.
Overix
Hi. Merry Christmas. Thanks for fresh release. Say please BH team got development plans in next year for update kernel version to 4.1.45 for other VU+ 4k models?
Overix
Found a bug. Firmware 3.0.8 with latest online update. Hotbird 13E TP 12539 H channel Hot Bird 4K1 has no sound and artifacts in picture. Also problem with Fashion TV 4K on same transponder, but problem much less, sometimes sound and picture stuck. With signal all fine and SNR around 70% All other channels from this satellite showing without any problems.
Please check it.
Ev0
Admin
Please check it.
OBH is the same, so must be a driver issue.
AlexWilMac
Moderator
But these are experimental channels. To be sure there would be a completely different receiver to try. Are we sure it's due to the VU+?
Matrix10
It's a channel problem
they sometimes have video without blocking and artifacts
but sometimes with large image blocking,not just on VU + but also on other E2 receivers.
Whether on all receivers, I do not know.
Matrix10
I can not agree with your comparison.
PC with Box.
Do you have a good picture on a receiver with hardware processing ?
Not PC
(hardware processing and software processing)
Video sign processing is not the same.
What does that mean
For example, if you include a timeshift you will have a better video on the box.
why
The most likely cause is the following.
Time stamps/timing in the stream are not transmitted OK in the stream. The issue is related to the provider that transmits the channel....
This is also confirmed by the fact that sometimes video is good and often bad.
ERIC >>Pli team:The reason why recordings often play back well is because then the decoder has access to the whole stream at once, instead being fed small chunks at a time.
I do not believe this problem can be solved with the driver.
if my assumption of cause is correct,which confirms the use of timeshift.
Eric Pli team
Besides that, the hardware is designed to work within the specifications of the standards. Once a providers starts to operate outside the area of the standards, the hardware isn't able to cope. That is not the fault of the hardware, but the providers fault. The reason why recordings often play back well is because then the decoder has access to the whole stream at once, instead being fed small chunks at a time.
Another possible reason is that the provider experiment with something that is not known,outside the area of the standards.
In principle, the whole 4K system is developing with all possible standards not covered by the current standards.
There will be problems.
Matrix10
To add that some have a problem with NASA TV UHD 13E
Solution is to put in A / V settings 50HZ instead of multi.
Why
Because some TVs lose HDMI synchronization
because that channel uses 60Hz (USA standard)
Overix
Today i checked channel Stingray Festival 4k on 36e ntv plus package. All works fine with sound. Thanks for fix this problem, great job. But other old bug with stuck picture with black screen and impossible change anything on receiver after set 10 or 12 bit colorbit with RGB option after cold boot still not resolved. Please check it too.
Matrix10 ye going beyond standards its also possible reason. Also i want say this channel Hotbird4k1 has highest bitrate what im know, around 31 Mbps.
AlexWilMac
Moderator
@Ev0
So far it has always been written: "This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash".
But today, after the 308A, you wrote that, for some models (Vu+ Solo, Duo, Uno), it is recommended to install it in omb. Can you specify what kind of problems there are for them if installed in flash (if they are not random)? I mean: do they affect the same features of functionalities?
Thanks
Ev0
Admin
@Ev0
Thanks
Since we re-added support for Solo, Duo and Uno, we have stated that the image should be installed in OMB with those models.
Simply because the flash space is so small on those boxes there is no free space to use any plugins (not even serviceapp).
MohamedOpera
Hello There,
First of all thx for the great image .. i really like it
i had faces a couple of issues which i need ur kind support in fixing it
1- Youtube is not working anymore...when i open it, it just give me black screen and never work
2- Kodi, it came pre installed on the image ver. 17 i guess...but its not working and refuse to get addons, so i just removed it by Idreamx (i am a mac user so do not have dcc) and now i do not have any kodi on my box, and when i tried to install it ver commands, it requested a password..which i do not know!!! and i tried to change it with password changer (from the image plugins) but it still says wrong password in the telnet...
so any recommendations to help me with that?
Thx in advance :)
angelofsky1980
BlackHole Driver Specialist
Hello There,
Thx in advance :)
If you have used original BH images, there is no root password setted up so leave blank password filend and all should works properly.
If the software you use needs a password to continue, put 1234 or anything you want in the password field.
If you try to connect with Telnet and the client asks a password and you never setted it up anymore, probably you are using a backup image (NOT SUPPORTED HERE) or someone hacks your box (and you MUST check your modem/router configuration in the port forward section).
MohamedOpera
Thanks for your reply
i am using the image from here in that post, so i think its original i guess... and everything work like charm but not the telnet...it keeps asking for password when i try to type any commands!!! someone hacked my box? how can i know that? get ride of it? my box is new and bought it from an official reseller a month ago
and i would like to use the commands to update Kodi as its completely refuse to add any addons (it works perfectly on openatv images) so if there is other way to update kodi without commands will be great
also the youtube addon that came pre installed on that image did not work, so any tweaks to fix it?
i really appreciate your kind support
Thanks
AlexWilMac
Moderator
Although you say you took the image from our forum, I'd like to be sure: did you install the image personally? Or did you get the box already installed?
MohamedOpera
i installed it personally, i am new to this but i have some IT background, so i read carefully and try to learn
