Black Hole 3.0.8 Vu+ Uno
Ev0
Admin
MERRY CHRISTMAS FROM THE BH TEAM
Black Hole 3.0.8
What is new ?
  • Many bug fixes
  • Added Serviceapp with Exteplayer3
  • New Bootlogo
  • Updated Mediatree to support more USB tuners
  • Updated Duo4K Drivers
*** DUE TO THE LIMITED FLASH SPACE, WE RECOMMEND THAT THIS IMAGE IS ONLY USED IN OMB (OpenMultiboot) WITH THIS MODEL ***
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- CrossEPG supported
- EPG Import supported
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
ServiceApp and Exteplayer3 are both external plugins, and are not part of the BH image, therefore any users that do not want / need to use these plugins, can remove them via the BH SpeedUp panel.
Credits:
Thanks to MX3L for ServiceApp https://github.com/mx3L/serviceapp/tree/develop
Thanks to SamSamSam for Exteplayer3 https://github.com/e2iplayer/exteplayer3
Thanks to dpeddi for patching ServiceApp and Exteplayer3 to work on BH.
Thanks to Pedro_Newbie for Backup script.
DISCLAIMER
LICENSE (TERM OF USE)
  • BlackHole-3.0.8-vuuno_usb_release_20181224_aa3715e.zip
Ev0
Admin
BH 3.0.8 onwards includes ServiceApp and Exteplayer3 which gives improved media playback / streaming performance.
It is pre-installed in all boxes, except Gen1 Solo, Duo, Uno, Ultimo and Zero, so you will have to enable it from the BH SpeedUp menu on those boxes.
To use it with IPTV, you can either leave the ServiceApp settings as default and in your IPTV lists, just change the #SERVICE 1:0:1: or #SERVICE 4097:01: to #SERVICE 5002:0:1:
Doing this, Exteplayer3 will only be used on your IPTV streams.
Or you can change the default setting of Enigma2 playback system in the ServiceApp menu from Original to Exteplayer3.
Note: that you can not record IPTV streams if you are using Exteplayer3 (however Enigma2 isn't reliable when recording IPTV anyway).
Changing the setting in the ServiceApp menu, means that the image will no longer use the built in Mediaplayer (linked to Gstreamer) and will use ExtePlayer3 for all media playback for IPTV and streaming aswell as any movies / recordings on your hdd, doing this you won't need to convert your IPTV lists to #SERVICE 5002:0:1:
But please note, that ServiceApp isn't perfect, it does not know the difference between Mpeg1 and Mpeg2 files, therefore it will report any Mpeg2 as Mpeg1 and the Zerok4K and Duo4K do not support Mpeg1, so even though these files are really Mpeg2 because ServiceApp reports them as Mpeg1 you will only get Audio on these files.
All other Vu+ boxes support Mpeg1 so it's not too much of an issue.
Also note that Subtitles will not work and trying to use Subtitles with Exteplayer3 may cause Enigma2 to crash, this is a known issue, and it is not something we can fix.
lenovo
Hi Evo, i install the image on my Vu+uno, after setup the settings and push the green button , the screen becomes green ? i post the crash log
  • enigma2_crash_1553.rar
Ev0
Admin
From the 1st post of this thread:
Sorry I don't know how to make it any clearer for you.
maztermind
There is something wrong in my vu +uno box when in menu speed up black hole galaxy -> ServiceApp -> i choose activate and it is installing and then rebooting the box but when i come backup to same menu it stil says deactivate.
what's wrong? i have disc space free.
Ev0
Admin
Unless you have it in OMB, then you do not have enough free space.
Ev0
Admin
I have around 5 MB free disc space before i install it, how much does it need?
More than that.
I didn't put this on the release post just for fun.
maztermind
Sorry for that then i guess i can use it, but how can i delete those files now to free up space? because it took my only 5 mb left.
i found another solution to work with IPTV now with bouquets.
Ev0
Admin
The only way is to reflash your box to recover that space.
