Black Hole 3.0.8 Vu+ Uno4K SE
Ev0
Admin
MERRY CHRISTMAS FROM THE BH TEAM
Black Hole 3.0.8
What is new ?
  • Many bug fixes
  • Added Serviceapp with Exteplayer3
  • New Bootlogo
  • Updated Mediatree to support more USB tuners
  • Updated Duo4K Drivers
This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- CrossEPG supported
- EPG Import supported
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
ServiceApp and Exteplayer3 are both external plugins, and are not part of the BH image, therefore any users that do not want / need to use these plugins, can remove them via the BH SpeedUp panel.
Credits:
Thanks to MX3L for ServiceApp https://github.com/mx3L/serviceapp/tree/develop
Thanks to SamSamSam for Exteplayer3 https://github.com/e2iplayer/exteplayer3
Thanks to dpeddi for patching ServiceApp and Exteplayer3 to work on BH.
Thanks to Pedro_Newbie for Backup script.
DISCLAIMER
LICENSE (TERM OF USE)
  • BlackHole-3.0.8-vuuno4kse_usb_release_20181224_aa3715e.zip
Ev0
Admin
BH 3.0.8 onwards includes ServiceApp and Exteplayer3 which gives improved media playback / streaming performance.
It is pre-installed in all boxes, except Gen1 Solo, Duo, Uno, Ultimo and Zero, so you will have to enable it from the BH SpeedUp menu on those boxes.
To use it with IPTV, you can either leave the ServiceApp settings as default and in your IPTV lists, just change the #SERVICE 1:0:1: or #SERVICE 4097:01: to #SERVICE 5002:0:1:
Doing this, Exteplayer3 will only be used on your IPTV streams.
Or you can change the default setting of Enigma2 playback system in the ServiceApp menu from Original to Exteplayer3.
Note: that you can not record IPTV streams if you are using Exteplayer3 (however Enigma2 isn't reliable when recording IPTV anyway).
Changing the setting in the ServiceApp menu, means that the image will no longer use the built in Mediaplayer (linked to Gstreamer) and will use ExtePlayer3 for all media playback for IPTV and streaming aswell as any movies / recordings on your hdd, doing this you won't need to convert your IPTV lists to #SERVICE 5002:0:1:
But please note, that ServiceApp isn't perfect, it does not know the difference between Mpeg1 and Mpeg2 files, therefore it will report any Mpeg2 as Mpeg1 and the Zerok4K and Duo4K do not support Mpeg1, so even though these files are really Mpeg2 because ServiceApp reports them as Mpeg1 you will only get Audio on these files.
All other Vu+ boxes support Mpeg1 so it's not too much of an issue.
Also note that Subtitles will not work and trying to use Subtitles with Exteplayer3 may cause Enigma2 to crash, this is a known issue, and it is not something we can fix.
drbmn
Thanks for the great job.. Is this stb (uno 4K se) with this new image compatible with the multistream channels on 5°W?? Tuner is S2X, so It should be I guess.
Thanks
Matrix10
Thanks
At this point, only Zero 4K is able to receive MIS channels.
bogdanm
Moderator
Hello Ev0.
How can I change the #SERVICE 4097:01: to #SERVICE 5002:0:1 in my iptv list?
Thank u very much .
Use editor?
Im used notepad++ ; is very easy becouse is option "change" in he you write 4097 to 5002 and editor change all.
adam13
Use editor?
Hello.
I have Notepad++ but how can I do it?
I have the iptv list open in a window of my computer, where to start?
Thank u.
bogdanm
Moderator
Hello.
Thank u.
Next find option " Find " in notepad after this rooldown and you see option "Change " [ CTRL +H ] .
In next window you find this whot you look.
adam13
Hello Bogdanm.
I'm here. Thank u very much my friend.
linuxsat2525
Hello Ev0.
Thank u very much .
copy gstplayer on usr / bin chmod 755
and fi the command
ln -sfn gstplayer /usr/bin/gstplayer_gst-1.0
7d52f13fff09fb4-jpg.42009
  • gstplayer.rar
Hello Ev0.
Thank u very much .
How do you create your Boquets? Do you use some plugin to convert your playlist to Enigma2 Boquets?
Some plugin like JediMakerExtream and E-Channelizer gives you the option to chose when creating boqutes what player you want to use.
If one does not work just make new with other settings. But almost all IPTV Channels works just fine with DVB1 intsead of 4097,5001or5002
And the nice thing with using DVB1 when creating boquets is that EPG is much easier to setup since epg id is generated same as Satchanels.
E-Channelizer free version gives you the option to change.edit and add on your computer then upload to your STB
