Black Hole 3.0.9.C Multistream Vu+ Duo4K
Ev0
Admin
What is new ?
  • Fix bug in downloader
  • Update CrossEPG
1-png.44697
2-jpg.44718
4-jpg.44700
5-jpg.44701
6-jpg.44690
7-jpg.44691
8-jpg.44692
9-jpg.44693
10-jpg.44694
11-jpg.44695
12-jpg.44696
This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- CrossEPG supported
- EPG Import supported
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
ServiceApp and Exteplayer3 are both external plugins, and are not part of the BH image, therefore any users that do not want / need to use these plugins, can remove them via the BH SpeedUp panel.
Credits:
Thanks to MX3L for ServiceApp https://github.com/mx3L/serviceapp/tree/develop
Thanks to SamSamSam for Exteplayer3 https://github.com/e2iplayer/exteplayer3
Thanks to dpeddi for patching ServiceApp and Exteplayer3 to work on BH.
Thanks to Pedro_Newbie for Backup script.
DISCLAIMER
LICENSE (TERM OF USE)
Problem maybe is no good signal or error in setting.
You try difrent setting or scan manual this transpnder ?
You have on this channel N/A ?
These are the parameters for your search:
30ºW Hispasat, , TDT Aragón, streaming + pls.
TP128, 11330 H 9140 3/4 DVB-S2 / 8PSK + PLS (GOLD 174526).
He asked the developers of this image to implant that driver please to be able to watch aragon hd by multistream on the hispasat satellite
duo 4k in blackhole image wifi in wlan connection not works, in solo 4k works well, i love blackhole but now i am using different image for this wifi problem, please fix it,
in openblackhole wifi works well in duo 4k but here is the sound problem when i update the image online
Doesn't matter: in case you should UP the message, not create a new thread. Otherwise, what would you do if even the 2nd thread is not answered? Will you create a 3rd, 4th, 5th.....?
Using Vu+ Duo 4k BH 3.0.9C
When I start playing a recording and want to fast forward to the actual start of the show (my default start time is 4 minutes before scheduled start time) I get a spinner and no response from the box for maybe as long as 30 seconds. Before this release, the show would fast forward immediately.
Is this a known issue or is there a fix for it?
Thanks I'm now on "L". There are still some delays with the spinner showing but it's not as bad as it was. I'll see how it goes for a while.
