Black Hole 3.0.9.C Vu+ Duo
Ev0
Admin
Black Hole 3.0.9.C​
What is new ?
  • Fix bug in downloader
  • Update CrossEPG
1-png.44697
2-jpg.44718
4-jpg.44700
5-jpg.44701
6-jpg.44690
8-jpg.44692
9-jpg.44693
10-jpg.44694
11-jpg.44695
12-jpg.44696
*** DUE TO THE LIMITED FLASH SPACE, WE RECOMMEND THAT THIS IMAGE IS ONLY USED IN OMB (OpenMultiboot) WITH THIS MODEL ***
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- CrossEPG supported
- EPG Import supported
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
ServiceApp and Exteplayer3 are both external plugins, and are not part of the BH image, therefore any users that do not want / need to use these plugins, can remove them via the BH SpeedUp panel.
Credits:
Thanks to MX3L for ServiceApp https://github.com/mx3L/serviceapp/tree/develop
Thanks to SamSamSam for Exteplayer3 https://github.com/e2iplayer/exteplayer3
Thanks to dpeddi for patching ServiceApp and Exteplayer3 to work on BH.
Thanks to Pedro_Newbie for Backup script.
DISCLAIMER
LICENSE (TERM OF USE)
Thank you. Tried v3 again after a long time on the Duo. It seems to work stably, except for HbbTV which does not start at all. Tried the red button, and tried the blue long press which brings up various HbbTV options. "HbbTV" appears on the front display for a split second but nothing happens. It works on BH 2.1.7 (not everywhere - it doesn't start on RAI's channels - software/hardware limitation perhaps?)
Also, on the Tuner Configuration section I get "unknown frontend" for the DVB-T stick. Works fine though (it's the old Hauppauge WinTV, the first one compatible with the Duo I think).
Sorry, and a question: are the 1080 skins not suitable? I tried one and got many crashes. Tried one of the few 720 available, and it works.
The duo is very old now, we did have 1080 skins for it, but the box was very slow and unstable so we removed them.
If you have the image in flash, that is probably why you have crashes as there is no space in flash for a 1080 skin.
