Black Hole 3.0.9.C Vu+ Duo2
Ev0
Admin
Black Hole 3.0.9.C​
What is new ?
  • Fix bug in downloader
  • Update CrossEPG
1-png.44697
2-jpg.44718
4-jpg.44700
5-jpg.44701
6-jpg.44690
8-jpg.44692
9-jpg.44693
10-jpg.44694
11-jpg.44695
12-jpg.44696
This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- CrossEPG supported
- EPG Import supported
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
ServiceApp and Exteplayer3 are both external plugins, and are not part of the BH image, therefore any users that do not want / need to use these plugins, can remove them via the BH SpeedUp panel.
Credits:
Thanks to MX3L for ServiceApp https://github.com/mx3L/serviceapp/tree/develop
Thanks to SamSamSam for Exteplayer3 https://github.com/e2iplayer/exteplayer3
Thanks to dpeddi for patching ServiceApp and Exteplayer3 to work on BH.
Thanks to Pedro_Newbie for Backup script.
DISCLAIMER
LICENSE (TERM OF USE)
BH3.0.9.I Hbbtv is not working ?
pressing <red> and the text hbbTVplugin is correctly shown in the display ….. but nothing is coming up on the TV … so the 2nd pressing <red> to activate hbbtv is not possible.
This has been working ok before.
Best regards
Best regards
Seems like it was not an image problem …
It is working as expected.
Sorry for the inconvenience.
Best regards
Hello
Is this image support VU + Bluetooth dongle adapter. I not see the BluetoothSetup i configuration menu ?
Vu Duo2 BH image
Some channels on Nile Sat and Badr 4 are not being detected. I have tired to update the satellite.xml, but the same issue. i updated the channels as well through Dreamset, also no success
1) you can always use the manual scan and insert the transponder you need.
2) Have you ever tried this page to immediately download an optimized satellites.xml?
 http://satellites-xml.org/
