Black Hole 4.0 Wifi Setup
dzs50
Could someone please tell me how I can access the wifi setup menu. I have tried looking in Network setup but this only shows the Lan configuration. I have a usb wifi adapter plugged in.
When you go into the Menu, Setup, Network, Devices, you should have 2 options, WLAN, and LAN.
What make/model USB WiFi adapter have you fitted?
Has it been recognized, by your receiver?
Thanks I will check the when I get back tomorrow. It has worked on black hole 3.0 image I seem to remember that I had to do something before the wifi menu appeared
I have to go Menu-Setup-System-Expert settings-Network
This gives me just the one Network configuration sub titled Lan connection but no Wifi .
I am not sure of the make/model of the USB Wifi adapter that I fitted, but it worked OK on a Black Hole 3 image.
I had rts37Usta selected in the driver list. There are no lights on , on the adapter so it looks like it is not being recognized , so hence the wifi option is not being listed?
You need to find the required driver.
If you managed to load it on Black Hole it should be similar with Open Black Hole.
What version of Open Black Hole are you running?
When was your last online update?
You did not answer my question: it seems, from your posts, you are NOT using BH 4.0 (that does not exist at all) but OpenBlackHole 4.1. If so, you posted in the wrong section. Provide us the need infos about your image, please.
Ok that makes more sense. If I go Main menu - Information - About . It states Black Hole 4.0. The file that I flashed the image from is
:- BlackHole-4.0_DM800_Sim2-SSl84D_20171201.nfi. Please let me know if I can provide any further information as this is all new to me.
I had previously used an image flashed from a file - BlackHole-3.0.2Final.
So I thought that BlackHole 4.0 was the next one in the series.
I need to change image as BlackHole-3.0.2Final only has allows the first 3 digits in the frequence field so that when the frequency for my area changed to 378250. I could not longer scan.
Oh dear... You downloaded something that has nothing to do with the real BlackHole, that's developed and distributed in this forum. As you should read yourself, you installed something for DM800.
Go to the appropriate section for your box in THIS SAME FORUM (you can find it in the home page) and downolad the real BH images, BH 305 or OBH 4.1 (OpenBlackHole).
The driver I used on BH 3 was already load on the image. As you can see from above I am sure what image I am using !!!
I did do an online update prior to posting my original question. If I loaded the BH 3 image where would I look for the wifi drivers?
Oh dear... snip
Just to clarify "THIS SAME FORUM" do you mean the site that I downloaded what was labelled as Blackhole 4.0?. Do you know if, BH 305 or OBH 4.1 (OpenBlackHole). will run on a DM800HD sim2 clone?
In the real BH there is no driver section: the drivers are already built-in.
In OBH, on the contrary, there is a driver section where you can install the driver for the devices you like (in case they are not already recognized by the image).
This is a VU+ forum, and genuine Black Hole images are based on the official VU+ image,
I advise that you either buy a genuine VU+ receiver or use a different image, as the Black Hole images, you're currently using, aren't really Black Hole.
My thanks to everyone for their help and advice and putting me straight about the various Black Hole images
THIS is HERE. To refer to the fake website where you downloaded that FAKE BH, I would have said THAT.
*** WARNING ***
No support for Vu+ clones stb´s and also no support for fake BlackHole images
The discussion stops here!
*** Thread Closed ***
