Black Hole Duo2 v.2.0.6 and fancontrol2
Gerry55
After upgrading to Black Hole Duo2 v.2.0.6 I'm unable to get fancontrol2 to read the temperature even after trying different versions of the plugin is that an image problem?
It's a plugin problem. FanControl2 it's an external plugin. Use the Manual FanControl plugin already avaiable into the image to setup your fan
Hi angelofsky1980
Thanks for the info, with v.2.o.5 FanControl2 would read the temp and you could also go to the FanControl2 web page but not now.
Where is Manual FanContol plugin? Cannot find it anywhere.
Into Green Panel ... press Green button and you see all plugins avaiable on your box ...
If you don't have ManualFanControl Plugin you should take a look into BH SpeedUp to enable it
I looked everywhere -There is no Manual Fancontrol plugin in 2.0.6c installed!!!
I have manual fan control plugin on my Duo2 with 2.0.6C
But I use fan control 2 plugin from the addon's server anyway.
