Black hole mount wizard
Qykario
Hi does anyoneone know if there's a plugin for the latest blackhole images to get the blackhole mount wizard back in the blue settings panel, i'm currently using blackhole 1.6.7 beta for that reason.
The new network mount manager is not an option it simply can't handle all network protocols and doesn't work on my network both linux mint and windows 7.
The blackhole mount wizard almost always works on most networks without having to change your computer settings to bad they removed it in the new images.
Thanks in advance.
