Black Hole not work with Neutrino Multiboot
Schrotty43
I use the Neutrino Multiboot with 4 Images on my UNO 4K SE. I have test many Images with the real Multiboot from Neutrino and only the Black Hole not work with this. After install i see only the Bootlogo.
udevd[975]: symlink '../fb0' '/dev/fb/0.udev-tmp' failed: Not a directory
Starting HOSTAP Daemon: Configuration file: /etc/hostapd.conf
Could not open configuration file '/etc/hostapd.conf' for reading.
Failed to set up interface with /etc/hostapd.conf
Failed to initialize interface
resolve: resolve ${datadir}/enigma2/encoding.conf
resolve: -> /usr/share/enigma2/encoding.conf
couldn't parse chi GB18030
couldn't parse zho GB18030
couldn't parse chn GB18030
couldn't parse fas UTF-8
couldn't parse per UTF-8
couldn't parse fa UTF-8
couldn't parse pes UTF-8
couldn't parse
couldn't parse
couldn't parse
couldn't parse
can't open /etc/enigma2/lamedb: No such file or directory
FATAL: pal.png not found!
FONT 'Regular' MISSING!
/usr/bin/enigma2.sh: line 38:  1960 Killed                  LD_PRELOAD=$LIBS /usr/bin/enigma2
Moderator
couldn't parse
couldn't parse
couldn't parse
couldn't parse
And why are you using a third party plugin, when you have OpenMultiboot embedded on image?
*** THIS IS NOT A BLACKHOLE IMAGE ISSUE ***
