Black Hole Speed UP
Safak Sonmez
Black Hole 2.0.9
I am trying to install Tuner Server and Media Tomb but...
I can not install / enable anything from SPEED UP on both DUO and SOLO.
OPKG update on telnet returns wget errors 1 and/or 255.
Will you please give clear instructions ?
Kind regards
Black Hole 2.0.9
Kind regards
Are you sure you have network and internet connection.
Check the network settings and gateway
