Black Hole Starting Guide
Betim118
I changed the satellites from Turksat to Digitalb and then lost the signal of Turksat .... after a while i rebooted the device and lost all satellites can someone help me i am a new user
Turksat usually refers to the satellites on 42E, whereas Digitalb is a package on 16E, so the problem seems to be with your dish, motor, cable, or LNB.
A re-boot shouldn't affect anything, unless you mean something else. How did you do this re-boot?
Are you using USALS, or Diseqc 1.2, to drive your motor?
Can you please supply more information, regarding your setup, your general location, dish size, and motor. Also your receiver and the image you have installed.
Have you checked the cable connection, at the rear of your receiver, to see if it has come lose?
I have also noticed that you have posted this thread in VU+ News, by mistake, hopefully a mod will soon move it to the correct section, for you.
I think U have correct assumption, and no need to move the question it is OK here!
