lorenzo64
- What is HBBTV?
HBBTV is a pan-European specification for interactive TV applications with its roll-out in Germany, France and more countries are now following. HBBTV has been developed in order to fulfil the needs of seeking ways to deliver interactive services through a single web-based user interface. The fundamental goal is to create open standards providing the seamless TV experience to customers.
- Note for Vu+ Ultimo and Vu+ Uno boxes:
Remeber to upgrade the firmware to the version 4.5 before you install Black Hole 1.7.7 - Note HbbTv:
To access HbbTv functions: Short press red button / Long press blue button - Warning Parallel Universes:
Bh parallel universe panel has been moved to: Long press red button
- What is new ?
- Vu+ dvb drivers updated to 20120824
- Vu+ OE updated to 20120830
- Vu+ Enigma2 updated to 20120830
- Army skin Transparency-HD updated for HbbTv
- [librtmp] fix build bug
- Enigma2-defaultservices : update default services
- Opera hbbtv:
- upgrade libdvbsi++ package.
- include hbbtv plugin.
- packaging opera-hbbtv binutil. - Fix libpcsclite build
- RemoteControlCode : support for all models except duo/solo.
- [firmware upgrade] fix fimrware data filename.
- Add opera browser.(with hbbtv)
- handle error for forbidden stream.
- activate red button.(ready for ait..) - keymap.xml: Red button remapped: short = hbbtv, long = parallel universes
- BhEi: fix satellite name and position in osd (thx Sato)
- Add filesystem choice to usb format wizard
- Remove Vu+ Device Manager, using Bh device panel instead.
- Set platform profile and check HbbTv application version.
- HbbTv: fix bug of setting orgid.
- Fix lamedb.192.
- [hbbtv] fix bugs.
- add platform profile.
- add application version.
- notify error for failed to load.
QUI
