Black Hole Vu+ Duo 2.0.2 Rev. D
lorenzo64
Black Hole 2.0.2 Rev. D
Cosa è nuovo:
The Black Hole 2.0.2 rev. D is the most stable release of 2.0.2 series.
  • New BlackHole api reloadsettings. (From telnet: Blackholecmd reloadsettings)
  • Don't crash on corrupted EPG data but prevent further damages.
  • Add sanitycheck on eventData buffer size.
  • Update cs language
  • [blindscan] added blindscan commands.
  • Fix another Dns settings bug and revert back to original Black Hole Dns fixed config system.
  • [wlan] added additional firmware file for Atheros USB wireless dongles (htc_7010.fw)
  • Opera HbbTv: bug fix ( after playing advertising, can't play a vod of SAT.1. )Skip opkg update in addons and bhspeed when lists are present in /tmp
  • [libs] updated libdvdcss to v1.2.13
  • New new new: Add parental control in Addons and settings. This can be useful to prevent downloading unprotected settings, porn plugins or streams.
  • New new new: Add scheduling (daily, weekly or montly) to autoupdate bh feed settings.
  • Black Hole feed settings: fix bug opkg upgrade -> opkg install.
  • Black Hole Speed Up: Remove extra files when hbbtv is disabled and add option to remove web manuals (this will save more than 5 Mb of flash).
  • Update French lang.
  • Media-tree: [Siano] Add SMS1XXX_BOARD_SIANO_NICE devices to request "smsdvb" kernel object (like some PC100 Greek devices done in the past).
  • opkg-collateral: download updated lists in Ram instead of Flash this will increase performaces but massive tested is required to check stability.
  • opkg-collateral: use only root for target
  • Skip opkg update in addons and bhspeed when lists are present in /tmp
  • New new new: Add a screen @ shutdown/reboot/restart e2 (thx to littlesat e pieterg)
  • fix framebuffer flicker
  • fix bug is osd Dvb-t info
Online upgrade available from previous 2.0.2 versions.
QUI
Installato plugin vps e reboot infinito con crash in avvio del v2, verificate.
Ma per LCN scanner ora non é presente sul plugin svdownloader come si fa?
where is the blindscan command? ı didnt find it.
You have to wait for new Rev. It's not BH fault. New Vu+ drivers were released today ;).
Devi aspettare nuova Rev. Non è la colpa del BH. Oggi sono usciti nuovi Vu+ drivers ;).
Sezione Italiana - Italian Section.
