Black Hole Vu+ Duo2 v. 2.0.6
lorenzo64
Black Hole 2.0.6
What is new ?
  • New Plugin Net Drive
  • New Coherence UPnP Renderer
  • New Coherence UPnP Server
  • Removed Dlna Djmount client Bh version
  • Removed Minidlna Bh version
  • Added Vu+ Dlna Browser (based on djmount)
  • Added Vu+ Minidlna server
  • Fix and Update MyTube plugin
  • Update lcd4linux
  • Update Openwebif
  • Update all dtt drivers
  • Update TranscodingSetup plugin
Vu+ Drivers:
  • 20130918
    - Fix transcoding problem(duo2)
  • - Fix vtuner problem(duo2, solo2)
  • - Support non bcma encrypted PCMWAV in media playback
    - Add missing entries in framerate_choices(duo2, solo2)
    - Support 4 vtuners(duo2, solo2)
    - Support transcoding in vtuner(duo2, solo2)
  • Fix 1080i problem (duo2)
  • Fix AC3 sound problem (duo2)
  • - Fix DTSHD downmix & passthrough
    - Support more than 4 tuners(vtuner) in duo2 and ultimo
    - Fix play/pause in solo2(when duo2's new remote control is used)
    - Fix Xcrypt card detection problem(duo2, solo2, uno, ultimo)
    - Support transcoding bitrate/framerate setup
    (solo2, 50K<bitrate<1M, Change is in effect in the subsequent connection )
Misc:
  • [dvbmediasink] support DDP patch.
  • Add curlftpfs
  • [wlan] added driver for Realtek 8188EU chipset
  • [mt7610u] Added D-Link DWA-171 Rev. B1
  • [wlan] Added new Realtek Driver - 8812A - 8821A who support AC standard
  • Update HbbTv
  • Add python packages: misc, shell, types
  • Update af9035 firmware.
  • Increase vtuner number in udev up to 4
  • TransCodingSetup : set defalut bitrate of SOLO2
  • TranscodingSetup : change bitrate range (solo2, 50k ~ 1M)
  • TranscodingSetup : add framerate settings (25k, 50k)
  • TranscodingSetup : add default button
  • TranscodingSetup : use notifiers for set change
  • AudioSelection : Dolby Digital downmix -> Dolby Digital / DTS downmix
  • ServiceInfo : crash fix.
  • Update languges Cs, Da, No, Ru, Sk, Sv
Howto Dlna Renderer:
Enable UpNP renderer in Black Hole Speed Up
Start Bubbleupnp, Devices, Renderers and choose duo2, solo2, solo or the box name available.
Then choose library choose a media and press play.
You will play your media to your box.
You can use native Samsung Galaxy player (video, gallery, media) by pressing *))) ] (allshare)
QUI
