Black Hole Vu+ SoloSE 2.1.7
lorenzo64
Black Hole 2.1.7 MultiBoot
WHAT IS NEW
    • New switch from MeoBoot to OpenMultiBoot to use different kernels and drivers for each installed image.
    • New skin MX i6p By Matrix10
    • Vu+ drivers 20150623
      - Fix tuning problem(AVL6211, duo2, solose)
      - Improve vtuner(satip support)
      - Fix scrambling bit in recording
      - Improve transcoding
    • Xbmc Support 576/720/1080 resolution
    • Updated Vuplus-Blindscan
    • Updated HbbTv
    • Updated WebManual
    • Added Sat>Ip Client
    • Included UiPositionSetup
    • Removed MeoBoot
    • Added OpenMultiBoot
    • Updated Lcd4Linux
    • Updated MediaTree (usb tuners drivers)
    • Fixed random socket error
    • [ScanSetup] fixed error on complete scan with T2 tuners
    • [ScanSetup] fixed TT3L10 automatic scan problem
    • [unicable] support JESS(EN50607) and update unicable.xml
    • AnimationSetup: set default to animations disabled
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
  • BlackHole-2.1.7-vusolose_usb_release_20150707_c6f93e5.zip
Poune
Hello,
Like the others images (official, OBH, VTI, OpenPli), I have always the same problem with this new one :
I've a Solo SE V2 Dual DVB-S2 and I can't configure Diseqc 1.1 + Diseqc 1.0 ... I have 8 LNBs : 2 X Spaun SAR 411 F (commited) on a Spaun SUR 420 F (Uncommited) ... It's OK for the 4 first LNBs (Input 1 on the SUR 420 F) but no signal for the 4 others on Input 2 ... I have the same config on my Azbox (OpenPli) and it work ?
After many tests, I can switch to input 2 only if I unplug one LNB on the corresponding SAR 411 ! And when I re-switch to Input 1, the entry BA (entry 3) on the corresponding SAR 411 has no signal ???
The conclusion is that Dual DVB-S2 tuner (or the VU?) cannot manage my Diseqc SAR 411 with 4 LNBs (but only 3) when the configuration is commited, uncommited ????
The solution I have for now is 3 LNBs on input 1, 3 LNBS on input 2 and 1 LNB directly on input 3 and the last LNB on input 4 (the two last with commited Diseqc command to none) ...
Is a driver problem?
Thanx to all.
Matrix10
SKIN DEFAULT BUG FIX HDD Initialisation BH 2.1.7 DOWNLOAD SKIN FROM BH image server >> Skins>> SKIN DEFAULT BH 2.1.7 (BUG FIX HDD Initialisation)
TPOTOAP
Still experiencing problems with my Videoguard CAM. Solo SE is constantly restarting in intervals of 1 minute. No error log is being created. This issue started with the release of 2.1.5. It does not happen when I watch channels from other satellites.
I have never had problems with the cam on images up to 2.1.4.
angelofsky1980
BlackHole Driver Specialist
Send to Vu+ (www.vuplus.com) your issue.
Matrix10
Why would I do that? I have no problems watching with the official Vu plus image. In my opinion, the issue clearly comes from black hole images 2.1.5 onward.
Which date has the official image which you tested
Which date for drivers ??
