Black Hole Vu+ Ultimo 1.6.7 kernel 3.1.1 beta
lorenzo64
Black Hole Vu+ Ultimo 1.6.7 Kernel 3.1.1 beta
THIS IMAGE HAS BEEN COMPILED WITH THE NEWEST LINUX KERNEL AVAILABLE FOR OUR BOXES.
WARNING: THIS IMAGE USES A NEW FILESYSTEM AND IT IS NOT COMPATIBLE WITH MULTIBOOT OR WITH OLD PERSONAL BACKUP.
THIS IMAGE HAS TO BE INSTALLED IN THE FLASH.
THE MOST COMMONLY USED USB TUNER DRIVERS ARE NOW INCLUDED IN THIS IMAGE AND ARE AUTO_DETECTED.(hauppauge win nova, aver volar, aver a867 ecc..)
THIS MEANS THAT YOU CAN BOOT THE IMAGE WITH THE USB TUNER INSIDE AND IT WILL BE IMMEDIATELY AVAILABLE AND WORKING.
For this reason the Usb dtt panel has been removed, because it is no longer needed.
More drivers will be available soon.
THE WIRELESS management has been changed to use the Vuplus proprietary system plugin and Wpa supplicant have been updated
to the latest version.
The HDMI-CEC panel has been removed because Black Hole firmware has switched to native Vuplus Hdmi-Cec implementation.
So you can now find Hdmi-Cec config in the plugins list.
This image is totally new inside.
Please report your tests and opinions.
Have fun !!
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Button Red = Start Record
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Devices Manager
Kernel Modules Manager (Kernel module operator)
Black Hole Mount Wizard (Mount points)
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Credits
DISCLAIMER
LICENSE (TERM OF USE)
  • BlackHole-1.6.7-vuultimo_usb.zip
DanielFran
BH Lover
Well, waiting that VU+ Ultimo is available to buy one! ;)
After that It will be my pleasure to try, test and report to this last BH image.
Thanks to BH Team.
index.php
index.php
index.php
This time the image is working
Just do not find emulators
Any issues not found
Native Wi-Fi works fine
index.php
angelofsky1980
BlackHole Driver Specialist
index.php
index.php
index.php
index.php
EMU and CAM software are not supported and it's forbidden to talk about them.
Please read and respect Board and Team rules.
If you don't find something, use Google.
No more posts with indications or talk about forbidden subjects.
Thanks
