Black Hole Vu+ Ultimo 2.0.3 Hyperspace
lorenzo64
Black Hole 2.0.3 Hyperspace
More Flash space available
Better performance
Great improvement of image quality in Solo2.
The codename of this image is a tribute to the past history of Black Hole series (one of the fastest ever images for the old dreamboxes).
Basically we have a new concept of image installation.
The Black Hole Speed Up is NOW INTEGRATED into the start wizard on the first configuration of the image after flashing and all applications can be enabled/disabled at the first boot configuration wizard.
You can choose to enable/disable features directly on first installation.
You can always access the Bh Speed Up panel later to enable/disable features.
With the package selection this way we can reduce the flash memory used and increase your box performance.
What is new:
NEW: kernel 3.3.8 (solo2)
NEW: Vuplus drivers:
- Fix deinterlacer problem (solo2, duo2)
- Support dual tuner blindscan (duo2, uno, ultimo)
- Fix SD video output problem when transcoding enabled (solo2)
- Enhance demux filtering (solo2)
- Support DTS-HD
- Add redundant interface to zapping mode
NEW: Greatly reduced image size due to the optimization of the building of larger packages.
NEW: Greatly improved image quality in Solo2 due to the new kernel and drivers
NEW: Better image performance (your Solo2 will fly).
Fixes and changes:
- Black Hole Speed Up integrated into start wizard.
- OpenWebif: install only pictures of your box (this will save even more flash space)
- [wlan] re-introduced RT3070 and RT2800USB drivers instead of the RT5572 issued driver
- Autoshutdown: plugin now defaults to inactive
- Fix tty0 > ttyS0 in populate-volatile.sh
Languages update:
- Czech
- Slovak
- French
- Greek
- hr
Warning: due to Kernel update and structural changes the Personal Backup of previous Black Hole images are not compatible with the 2.0.3 version.
The image MUST be installed in flash.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
Black Hole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
  • BlackHole-2.0.3-vuultimo_usb.zip
pvdhelm
tnx for the image works great on my ultimo. The only thing i miss is fastscan. Hope it wil be soon availeble for blackhole images
tnx team
