Black Hole Vu+ Ultimo v. 2.0.7
lorenzo64
Black Hole 2.0.7
  • Update skin to Matrix10 MX S2
  • New drivers 20131023
  • - Support DVB T2 Tuner(uno, ultimo, duo2)
  • - Support file transcoding(solo2, duo2 : needs an image update)
  • - Fix delivery system bug in vtuner
  • - Fix DDP passthrough(solo2, duo2)
  • [transcoding setup] support filestreamproxy(8003).
  • Update OpenWebInterface
  • [mt7610u] new driver v3.0.0.1
  • [mt7610u] added new driver v3.0.0.2
  • [blindscan] fixed bug in ScanNimsocket function.
WARNING: This Image has the latest drivers and CAN NOT be installed in multiboot. The image MUST be installed in flash. Black Hole does not support images not installed in flash.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits Thanks to Pedro_Newbie for Backup script
DISCLAIMER
LICENSE (TERM OF USE)
  • BlackHole-2.0.7-vuultimo_usb.zip
NEUROSURGERY
Hi
Since version 2.0.6, I have a problem of sound, which appears in some channels and which disappears after a new change, it seems slaps when they are torn, the problem is still present even in 2.0.7, and can hear it even when I put mp3 or flac files in mediaplayer.
Anybody else that this problem?
I returned to version 2.0.5 and the problem disappeared!
Matrix10
Hi
Which channels ?
Matrix10
it is not a specific channel, I can have it on any channel, and I have to zap it back to disappear! even with mediaplayer when I listen to music.
thanks
I'm afraid I do not have it.
But it's too late for a new test.
Maybe someone can test now if not I'll try tomorrow.
superglud
BH Lover
BH2.0.7
My Ultimo's "standby mode LCD clock" stopped running.
Could not turn on my ultimo from standby mode, the box is unresponsive.
Had to turn off and on from main button behind, to get the box up and running.
This has happened twice already
Best regards
