Blackhole 1.6.6 - SCR configruation on both tuners
Mfsav2
Can you help me configure the tuners to take full advantage of the SCR?
I was able to configure a single tuner but do not know how to configure the second...
The cable is attached to Tuner 1...
It should be possible to configure both of them so that I can watch while recording.
Thank you for the help.
What is SCR ???
You can with only one and the same antenna/LNB record and watch from the same transponder but not at different transponders/at different frequency or different satellites.
For this you need a separate antenna / LNB for the second tuner.
So the configuration for your situation with one cable/LNB/Antenna is pass-true
this is my configuration:
1 cable from LNB SCR connected to tuner A
I can record and watch from different transponder
Tuner A
Sat: Hotbird
LNB: LNB 1
Priority Auto
LOF Unicable
Unicable Mod: Unicable User defined
Channel: SatCR 1
Frequency 1210
LOF/L 09750
LOF/H 10600
threshold 11700
connected NO
DiSEqC NO
Tuner B
Sat: Hotbird
LNB: LNB 1
Priority Auto
LOF Unicable
Channel: SatCR 2
Frequency 1420
LOF/L 09750
LOF/H 10600
threshold 11700
connected yes
connected to TUNER A
DiSEqC NO
Tuner A
Sat: Hotbird
LNB: LNB 1
Priority Auto
LOF Unicable
Channel: SatCR 1
Frequency 1210
LOF/L 09750
LOF/H 10600
threshold 11700
connected NO
DiSEqC NO
Tuner B
Sat: Hotbird
LNB: LNB 1
Priority Auto
LOF Unicable
Channel: SatCR 2
Frequency 1420
LOF/L 09750
LOF/H 10600
threshold 11700
connected yes
DiSEqC NO
Thank you very much!
Yes, this ist correct for HotBird 13East.
Attention: unicable have Limited user channels. One Tuner Need = One Channel, two Tuner Need two different Channel !
Könnt mich im deutschen Bereich kontaktieren, mein englisch ist nicht gut.
Thank you, Great!
Now it appear to be working.
The only funny thing is that sometimes it refuses to schedule overlapping records... is that correct?
