BlackHole 1.7.8 Skins
junzo
Hello,
Do you have some skins for this Blackhole 1.7.8 version please ? (using a Vu+ Solo)
Trying to install those who comes with it but they didn't work ...
Thanks !
Please download from feed ; you see on server skins who will be work on your version image.
If you install skin from other image he no will be work.
Thanks for your reply, can you tell me how to do this please ?
Using the remote to go to sknis downlow section did not work for me.
Yes this way worked ! thanks.
Where can i find others skins please ?
i'm searching a skin with a circle (when pressing "ok" button there was not a rectangle but a circle at this place).
Yes i've done it, i don't think this skin is in the panel. It should be downloaded anyway and installed separately
hi there, what are skins and how do i intall them? sorry if this is dum question but never done this and learning what more i can do with my new solo2
thanks for your help in advance.
Green>Yellow>addons Dload Manager> BH Image Skins!
Pick the one suitable for the BH Image you have!
