Hi guys.
My dish one day stopped working, i played a bit with the settings and it dident got better, seems the dish was frosen and now it is moving but i cant get the SNR above 0%, sometimes it jumps to somthing and then its back to 0% again so i assume its a software thing and not real receiving.
So i just installed the new BH 1.7.9 without restoring my previous settings cause its obviously massed up.
I have a motorized dish with 2 outputs and i use only the A to my VU+ Duo.
In the Tuner settings (USALS) i put it on configuration mode: simple - mode - positioner - Longtitude 012.397 east and 055.753 Latitude , North, info i picked up from her: http://itouchmap.com/latlong.html
When i do Auto search i get 0 out of 0 and manual is the same and the sat finder can only catch AGC, no SNR and no BER.
I played with the tuner settings and put it on DISEqC and all the other options but nothing seems to work so i read some on google about Upgrade FPGA which i guess is Firmware update and saw also that in some BH images there were Warnings that you have to update the FPGA before installing the BH image, so i dont know if thats what i miss and if so where can i get it?
sorry for the loooooong description but im a newbie and cant make it clearer then that.
Thanks in advanced!
Thanks in advanced!
