BlackHole 1.7.9 to 2.1.x ?
katolo
I plan to upgrade my box from 1.7.9 to the most recent version. Is there anything extra than the normal flash procedure I need to think of, or should I just flash it as normal. (there was once before where I had to also update the bootloader).
And I also guess I there is no possibilities for me to do a backup of my settings (and restore on 2.1.x), or?
Thanks for the link, but it still does not answer the first question. I know how to flash images. My question is, can I just take the most recent image and flash it. Or is there anything I need to do before, like upgrade bootloader?
If you are using BH 1.7.9 it means that you have already upgraded the boot loader.
Therefore, you can install the last image without problems.
Moreover, you can use software manager to backup your settings: http://www.vuplus-community.net/boa...-0-2-to-2-0-3-saving-all-your-settings.12684/
