blackhole 2.0 rev a problem
cozmo
i have a vu+ duo that i have been running blackhole 1.79 on for a wile now with no problems. I have installed BH 2.0 and all worked well apart from the green screen when exit system info so i installed the 2.0 rev a update and the green screen was gone from system info exit but now i have another problem after i install rev a if i go to blackhole settings and go to devices manager i get message scanning for devices and then green screen without rev a it will show my hdd straight away and also whit rev a when i go to swap file settings i cannot create a swap file just get check hdd for space and i cannot delete swap file or activate swap file says failed but without rev a on black hole 2.0 all good apart from green screen on system info when exit
thanks cozmo
sorry cannot not at mo as im back on 2.0 without rev a and it only will do it wile im on rev a and box is in use and im at work
i see in the info for the bh 2.0 image that it says to delete the vuplus folders from the hdd with i have not done so im guessing that could be my problem. can some tell me dose this mean that i need to format the hdd or just delete the folder vuplus from the hdd as i have a lot of recordings in the media/hdd/movies folder and misses will kill me if i delete them lol i can only find one vuplus folder that's in media/hdd is that the only one i need to delete
thanks
cozmo
thanks
cozmo
Remove or rename the folder "vuplus".
