Blackhole 2.1.5 Image Iptv Problem
Nicky
Each time i try to install Xtream-Codes Iptv Script E2.2 it never works and an error message comes up "Service not Found". When we install the E1.6 it works ok but i have problems with some streams. Then I install openatv image and E2.2 works excellent with all streams.
Can this problem be fixed?
I've seen from the web that the IPTV list you have mentioned in your post is a pay-system ... so ask them to provide you a compatible list.
IPTV Not working in BH 2.1.5 because the incoming changes , wait for updates from VU+ .
You can use BH 2.1.4 with IPTV and is working.
Iptv is working very good for me in BH 2.1.5
King regards
Enviado desde mi GT-I9505 mediante Tapatalk
Hello Folks, any news about iptv in bh 2.1.5? seems the only way to use it, is changing '#SERVICE 1:0:1:0:0:0:0:0:0:0 to #SERVICE 4097:0:1:0:0:0:0:0:0:0 but not the right choice with .ts
Thx.
just arrived, a friend handed me a file for enigma2 with IPTV, made with putty I created a new list you see the EPG but it gives me no channel found (sid not found in pat) is inside the black hole214. Can someone please help me? Greetings to all the forum
