BlackHole 2.13 wireless problem on Alliance image on Meoboot
sat24eb
Hi
I installed Black Hole 2.13 on my Vu DUO2 on flash. Everything works fine. I tried to install on Meoboot some images like Open ATV 4.2, Open Vix Apollo etc.. and I have a same problem.
It is impossible to enable wireless. When I configure Wireless network and I activate it , the vu duo2 freeze and reboot a few mn later without installing the wireless network.
The local network works without any problem.
I tested also VTI 7.01 image on Meoboot and I don't have any problem to configure wireless with this image. Everything works.
Do you know if it is possible to solve this problem as I use only wireless network.
Thanks a lot for your help and sorry for my english
Unfortunately I see that I cannot get help for my problem.
The new BlackHole 3.13 come with this good opportunity to install all major images with the Meoboot.
I tried this new option and I find that Meoboot delete all wifi driver for some images.
Can anybody now how to make the wireless working again.
Sorry formy bad english
