Blackhole 3.0.1F/2160 resolution
meisterhim
Hello,
I posted these issues elsewhere but no one answered.
There are two issues I can not resolve.
1) I installed Blackhole 3.0.1F(robijay) that has 4 satellites. Can I somehow swap 28.2 with 16 degrees east? I do not have 28.2. I tried all but no idea how.
2)I can not switch to the highest resolution 2160. When I switch to the screen turns to black. Move back to 1080p and all back to normal.
I use HDMI 2.0 that supports highspeed ethernet and 4K.
I got Samsung Curved 4K, Vu+Solo 4K and Yamaha RX-V773 that supports 4K pass through and 4K upscaling.
Regards,
Blagoj
Hello,
Regards,
Blagoj
I think you are talking about a version ( backup version ) of BlackHole 3.0.1F ...
We don´t support backups.
I have no clue what is a back-up version or regular one. Can you explain please? Will it work if I flash another version from here? Link pls
Hello,
Regards,
Blagoj
1. fucking backup version made by someone are not tolerated here.
Use ONLY BH original stock images downloaded from this Board.
Take a look in the Vu+Solo 4K section.
All right! I will do that. I hope i did not offend anyone with it. I have no idea what is it. I downloaded, flashed it for a first time and that is it.
Any idea if the image is causing the issue under 2 too?
If i install an image on my Vuplus Duo2, that is working normally for me with my configuration, could probably give some issues on the same model ( using backup ), why?
1) Different used tuners and wifi devices.
2) Different internet and network connections.
3) I could have there settings ( network settings ), that you don´t use on your system.
4) If i have a complete backup of my installed image ... i can restore it with no problems in my STB ( because i don´t change my system ), although as you system configuration is severall different the system probably hangs.
5) If you install a backup from other ... the network settings probably ... are not the same and the system will be spinning and spinning around trying to find the correct network settings.
Also you will learn more about how to use your sat box and Blackhole if you do it all yourself. You can make back ups of you own image (settings etc) which is wise to do. You will have more fun doing it yourself the guys and girls on this forum will help you out. But take a few days and look at all the stuff on this forum. I bet all your questiions will have ready answers somewhere on this forum
