Blackhole 3.0.1F dvb-t problem
malakantes
Hi, to all.
First of all thank you for your great firmware to the blackhole team and for your hard work.
I have a vusolo2 , used it with 2.1.4 for a long time without any problem. Today i had some free time and decided to update to the newest version. I updated to 3.0.1C and with online update it went to 3.0.1F. everything until now works great i haven't encoutered any issues but with my dvb-t tuner. It's a usb ASUS U3000hybrid, that has been working great until 2.1.4 version. Now i can see it, set up europe dvb-T but now channels found.
What can i do?
Thank you in advance for any reply
Hi, to all.
What can i do?
http://www.vuplus-community.net/boa...images-debug-script-per-le-immagini-bh.21512/
Hi angelofsky1980 and thank you for the reply.
This is the file generated from your script.
Sorry to post it this way but i don't have enough posts to be able to upload the txt file. :/
Box Info
Kernel: Linux vusolo2 3.13.5 #1 SMP Fri Nov 20 20:38:51 CET 2015 mips GNU/Linux
BH Ver: BlackHole 3.0.1
USB devices
Bus 001 Device 002: ID 0781:5567
Bus 002 Device 002: ID 05e3:0608
Bus 001 Device 001: ID 1d6b:0002
Bus 002 Device 001: ID 1d6b:0002
Bus 003 Device 001: ID 1d6b:0002
Bus 004 Device 001: ID 1d6b:0002
Bus 005 Device 001: ID 1d6b:0001
Bus 006 Device 001: ID 1d6b:0001
Bus 007 Device 001: ID 1d6b:0001
Bus 008 Device 001: ID 1d6b:0001
Bus 002 Device 003: ID 0b05:1736
Kernel Messages
scsi 2:0:0:0: Direct-Access SanDisk Cruzer Blade 1.27 PQ: 0 ANSI: 6
sd 2:0:0:0: Attached scsi generic sg0 type 0
sd 2:0:0:0: [sda] 31266816 512-byte logical blocks: (16.0 GB/14.9 GiB)
sd 2:0:0:0: [sda] Write Protect is off
sd 2:0:0:0: [sda] Mode Sense: 43 00 00 00
sd 2:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
sda: sda1
sd 2:0:0:0: [sda] Attached SCSI removable disk
UBI: scanning is finished
UBI: attached mtd0 (name "rootfs", size 225 MiB) to ubi0
UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
UBI: good PEBs: 1792, bad PEBs: 8, corrupted PEBs: 0
UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
UBI: max/mean erase counter: 84/52, WL threshold: 4096, image sequence number: 1835937857
UBI: available PEBs: 0, total reserved PEBs: 1792, PEBs reserved for bad PEB handling: 32
UBI: background thread "ubi_bgt0d" started, PID 55
ALSA device list:
No soundcards found.
UBIFS: parse sync
UBIFS: background thread "ubifs_bgt0_0" started, PID 58
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
UBIFS: FS size: 221573120 bytes (211 MiB, 1745 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
UBIFS: reserved for root: 0 bytes (0 KiB)
UBIFS: media format: w4/r0 (latest is w4/r0), UUID 0DE86686-8BCC-4B49-85DC-E725DE245633, small LPT model
VFS: Mounted root (ubifs filesystem) on device 0:12.
devtmpfs: mounted
Freeing unused kernel memory: 192K (80760000 - 80790000)
UBI error: ubi_open_volume: cannot open device 0, volume 0, error -16
EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
udevd[82]: starting version 182
WARNING: You are using an experimental version of the media stack.
As the driver is backported to an older kernel, it doesn't offer
enough quality for its usage in production.
Use it with care.
Latest git patches (needed if you report a bug to linux-media@vger.kernel.org):
b2d1467ad0461049c0de8f82f514447b0b8f016b tryfix v4l2_ctrl_check duplicate symbol #2
64955823cf3bd80743f1f3a5f7d50bd599d8affc tryfix v4l2_ctrl_check duplicate symbol - modify header
e8812dab0d410e2694451a73b421df6fd82b3b07 Merge branch 'bh-master_20140924_bh_dvb_usb_v2' of git.blackhole-community.net:repos/bh/vuplus_kernel into bh-master_20140924_bh_dvb_usb_v2
Use it with care.
dvb-usb: found a 'Asus My Cinema-U3000Hybrid' in warm state.
dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
DVB: registering new adapter (Asus My Cinema-U3000Hybrid)
usb 2-1.3: DVB: registering adapter 1 frontend 0 (DiBcom 7000PC)...
xc2028 1-0061: creating new instance
xc2028 1-0061: type set to XCeive xc2028/xc3028 tuner
usb 2-1.3: Direct firmware load failed with error -2
usb 2-1.3: Falling back to user helper
xc2028 1-0061: Could not load firmware xc3028-v27.fw.
IR keymap rc-dib0700-rc5 not found
Registered IR keymap rc-empty
input: IR-receiver inside an USB DVB receiver as /devices/platform/ehci-brcm.1/usb2/2-1/2-1.3/bh-rc/rc0/input0
rc0: IR-receiver inside an USB DVB receiver as /devices/platform/ehci-brcm.1/usb2/2-1/2-1.3/bh-rc/rc0
dvb-usb: could not initialize remote control.
dvb-usb: Asus My Cinema-U3000Hybrid successfully initialized and connected.
usbcore: registered new interface driver dvb_usb_dib0700
procmk_init
bcm_event: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
DVB: registering new adapter (_vuplus_solo2_)
bcm7356: hotplug_callback():
Hotplug - status.connected 1:0:0
Hotplug - connecting HDMI to display 0xe
[GP]:brcm_pwm_init
Hotplug - status.connected 1:1:2
brcm_demux_init: $Id: bcm_demux.c,v 0.7 $
[MPVR]: >> misc_pvr_init
[VID]: 6bcm7335_video_init
[AUD]: 6bcm7335_audio_init
BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (BCM7346 FE)...
BKNI_P_GetTrackAllocEntry_resize: resizing from 5376->8704
BKNI_Malloc(linuxkernel) top users:
blocks, bytes, filename:line
1024, 176128, portinginterface/hsm/src/common/bhsm.c:500
598, 132056, BSEAV/lib/utils/balloc.c:31
386, 24704, magnum/commonutils/mrc/src/bmrc_monitor.c:666
input: dreambox advanced remote control (native) as /devices/virtual/input/input1
[LCD]: registered
0:0
[CI]: registered ci0
[CI]: CI interface initialised
[DFP]: registered dbox fp
[DFP]: Scart 9597 is found 4
[SC]: registered sci0
[SC]: registered sci1
system_time_set wakeup mode get
system_time_set wakeup mode get 0xc4
[VID]: VIDEO_SET_STREAMTYPE 0
[VID]: VIDEO_SELECT_SOURCE 1 0
[VID]: VIDEO_PLAY 1 2 0
[VID]: VIDEO_CONTINUE 1 1
[VID]: VIDEO_CLEAR_BUFFER 1 1 0
__clk_enable: network [1]
__clk_enable: enet [1]
bcm40nm_pm_genet_enable 00
[VID]: VIDEO_STOP 0 1
[VID]: VIDEO_SELECT_SOURCE 0 0
bcmgenet bcmgenet.0 eth0: link up, 100 Mbps, full duplex
NET: Registered protocol family 10
BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (DiBcom 7000PC)...
[LCD]: unknown cmd 0x1015
[AUD]: AUDIO_SET_MUTE 0
[AUD]: AUDIO_SET_MIXER -871219728
[AUD]: AUDIO_SET_MIXER : amixl 0, amixr 0
[AUD]: AUDIO_SET_MIXER : next left volume 0, right volume 0
[AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
[AUD]: AUDIO_SET_MIXER : amixl 7, amixr 7
[AUD]: AUDIO_SET_MIXER : next left volume -570, right volume -570
FE tune
dvb_demux_feed_del: feed not in list (type=0 state=0 pid=ffff)
[AUD]: AUDIO_SET_BYPASS_MODE 0
[AUD]: AC3 downmix 0 state : 0
[AUD]: AUDIO_PAUSE 0
[AUD]: AUDIO_PLAY 0 decoder start : 0
[VID]: VIDEO_SET_STREAMTYPE 1
[VID]: VIDEO_FREEZE 0 0
[VID]: VIDEO_PLAY 0 5 2
[VID]: VIDEO_SLOWMOTION 0 1
[VID]: VIDEO_FAST_FORWARD 0 1
[VID]: VIDEO_CONTINUE 0 1
[AUD]: AUDIO_CONTINUE 0 1 aph=0xcc3b7300
[AUD]: Mute : 0
[AUD]: AUDIO_CHANNEL_SELECT 0
[AUD]: Mute : 0
[VID]: VIDEO_GET_SIZE src w: 0 h:0 display w:0 h:0
[VID]: VIDEO_GET_SIZE aspect: 1 0
[VID]: VIDEO_STOP 1 1
[AUD]: AUDIO_STOP 0
[AUD]: AUDIO_CONTINUE 0 0 aph=0x0
[AUD]: AUDIO_CONTINUE aph=0 0 0
FE tune
[AUD]: AUDIO_CONTINUE 0 1 aph=0xcebc2880
[AUD]: Mute : 0
[AUD]: Mute : 0
[AUD]: AUDIO_STOP 0
[AUD]: AUDIO_SET_BYPASS_MODE 8
[AUD]: AAC downmix 0 state : 0
[AUD]: AUDIO_CONTINUE 0 1 aph=0xcebc2900
[AUD]: Mute : 0
[AUD]: AUDIO_STOP 0
[AUD]: AUDIO_CONTINUE 0 1 aph=0xcc338480
[AUD]: Mute : 0
[AUD]: AUDIO_STOP 0
[AUD]: AUDIO_CONTINUE 0 1 aph=0xc6cf3780
[AUD]: Mute : 0
[VID]: VIDEO_GET_SIZE src w: 1280 h:720 display w:1280 h:720
[VID]: VIDEO_GET_SIZE aspect: 1 6
[AUD]: AUDIO_STOP 0
FE tune
[AUD]: AUDIO_CONTINUE 0 1 aph=0xcc297680
[AUD]: Mute : 0
[AUD]: Mute : 0
NIM Sockets
NIM Socket 0:
Type: DVB-S2
Name: BCM7356 DVB-S2 NIM (internal)
Frontend_Device: 0
NIM Socket 1:
Type: DVB-S2
Frontend_Device: 1
NIM Socket 2:
Type: DVB-T
end
Frontend_Device: 2
Modules Loaded
Module Size Used by
ipv6 332460 34
brcmfb 1590 4
dvb_bcm7356 1425402 24 brcmfb
dvb_base 4584137 187 dvb_bcm7356
bcm_event 2821 5 dvb_bcm7356
procmk 1668 2 dvb_bcm7356,bcm_event
ext2 57304 0
tuner_xc2028 21193 1
dib7000p 30631 1
dvb_usb_dib0700 99716 2
dib3000mc 11287 1 dvb_usb_dib0700
dib9000 28868 1 dvb_usb_dib0700
dib0070 8187 1 dvb_usb_dib0700
dib7000m 14911 1 dvb_usb_dib0700
dibx000_common 7102 5 dib9000,dvb_usb_dib0700,dib3000mc,dib7000m,dib7000p
dib0090 24876 1 dvb_usb_dib0700
dvb_usb 22013 1 dvb_usb_dib0700
bh_rc_core 19039 2 dvb_usb,dvb_usb_dib0700
bh_dvb_core 87742 3 dib9000,dvb_usb,dib7000p
Kernel Objects
/lib/modules/3.13.5
/lib/modules/3.13.5/modules.builtin.bin
/lib/modules/3.13.5/modules.symbols.bin
/lib/modules/3.13.5/kernel
/lib/modules/3.13.5/kernel/fs
/lib/modules/3.13.5/kernel/fs/fat
/lib/modules/3.13.5/kernel/fs/fat/msdos.ko
/lib/modules/3.13.5/kernel/fs/nls
/lib/modules/3.13.5/kernel/fs/nls/nls_cp850.ko
/lib/modules/3.13.5/kernel/fs/ext2
/lib/modules/3.13.5/kernel/fs/ext2/ext2.ko
/lib/modules/3.13.5/kernel/fs/fuse
/lib/modules/3.13.5/kernel/fs/fuse/fuse.ko
/lib/modules/3.13.5/kernel/fs/ntfs
/lib/modules/3.13.5/kernel/fs/ntfs/ntfs.ko
/lib/modules/3.13.5/kernel/fs/reiserfs
/lib/modules/3.13.5/kernel/fs/reiserfs/reiserfs.ko
/lib/modules/3.13.5/kernel/lib
/lib/modules/3.13.5/kernel/lib/crc-ccitt.ko
/lib/modules/3.13.5/kernel/net
/lib/modules/3.13.5/kernel/net/802
/lib/modules/3.13.5/kernel/net/802/stp.ko
/lib/modules/3.13.5/kernel/net/llc
/lib/modules/3.13.5/kernel/net/llc/llc.ko
/lib/modules/3.13.5/kernel/net/ipv6
/lib/modules/3.13.5/kernel/net/ipv6/ipv6.ko
/lib/modules/3.13.5/kernel/net/wireless
/lib/modules/3.13.5/kernel/net/wireless/lib80211.ko
/lib/modules/3.13.5/kernel/net/bridge
/lib/modules/3.13.5/kernel/net/bridge/bridge.ko
/lib/modules/3.13.5/kernel/net/mac80211
/lib/modules/3.13.5/kernel/net/mac80211/mac80211.ko
/lib/modules/3.13.5/kernel/drivers
/lib/modules/3.13.5/kernel/drivers/net
/lib/modules/3.13.5/kernel/drivers/net/usb
/lib/modules/3.13.5/kernel/drivers/net/usb/cdc_subset.ko
/lib/modules/3.13.5/kernel/drivers/net/usb/cdc_eem.ko
/lib/modules/3.13.5/kernel/drivers/net/usb/rndis_host.ko
/lib/modules/3.13.5/kernel/drivers/net/usb/usbnet.ko
/lib/modules/3.13.5/kernel/drivers/net/usb/cdc_ether.ko
/lib/modules/3.13.5/kernel/drivers/net/usb/zaurus.ko
/lib/modules/3.13.5/kernel/drivers/net/tun.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/ath9k
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/ath9k/ath9k_common.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/ath9k/ath9k_hw.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/ath9k/ath9k_htc.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/ath.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/carl9170
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/carl9170/carl9170.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/8192cu.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/hostap
/lib/modules/3.13.5/kernel/drivers/net/wireless/hostap/hostap.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/8812au.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rtl818x
/lib/modules/3.13.5/kernel/drivers/net/wireless/rtl818x/rtl8187
/lib/modules/3.13.5/kernel/drivers/net/wireless/rtl818x/rtl8187/rtl8187.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/mt7601Usta.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/mt7650u_sta.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/zd1211rw
/lib/modules/3.13.5/kernel/drivers/net/wireless/zd1211rw/zd1211rw.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00/rt73usb.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00/rt2x00usb.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00/rt2800usb.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00/rt2500usb.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00/rt2x00lib.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00/rt2800lib.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/8188eu.ko
/lib/modules/3.13.5/kernel/drivers/mtd
/lib/modules/3.13.5/kernel/drivers/mtd/nand
/lib/modules/3.13.5/kernel/drivers/mtd/nand/nandsim.ko
/lib/modules/3.13.5/kernel/drivers/usb
/lib/modules/3.13.5/kernel/drivers/usb/class
/lib/modules/3.13.5/kernel/drivers/usb/class/cdc-acm.ko
/lib/modules/3.13.5/kernel/drivers/usb/serial
/lib/modules/3.13.5/kernel/drivers/usb/serial/usbserial.ko
/lib/modules/3.13.5/kernel/drivers/usb/serial/cp210x.ko
/lib/modules/3.13.5/kernel/drivers/usb/serial/pl2303.ko
/lib/modules/3.13.5/kernel/drivers/usb/serial/ftdi_sio.ko
/lib/modules/3.13.5/kernel/drivers/misc
/lib/modules/3.13.5/kernel/drivers/misc/eeprom
/lib/modules/3.13.5/kernel/drivers/misc/eeprom/eeprom_93cx6.ko
/lib/modules/3.13.5/kernel/drivers/scsi
/lib/modules/3.13.5/kernel/drivers/scsi/sr_mod.ko
/lib/modules/3.13.5/kernel/drivers/cdrom
/lib/modules/3.13.5/kernel/drivers/cdrom/cdrom.ko
/lib/modules/3.13.5/kernel/drivers/media
/lib/modules/3.13.5/kernel/drivers/media/rc
/lib/modules/3.13.5/kernel/drivers/media/rc/bh-rc-core.ko
/lib/modules/3.13.5/kernel/drivers/media/i2c
/lib/modules/3.13.5/kernel/drivers/media/i2c/cx25840
/lib/modules/3.13.5/kernel/drivers/media/i2c/cx25840/cx25840.ko
/lib/modules/3.13.5/kernel/drivers/media/i2c/saa7115.ko
/lib/modules/3.13.5/kernel/drivers/media/i2c/msp3400.ko
/lib/modules/3.13.5/kernel/drivers/media/i2c/tvp5150.ko
/lib/modules/3.13.5/kernel/drivers/media/i2c/mt9v011.ko
/lib/modules/3.13.5/kernel/drivers/media/i2c/ir-kbd-i2c.ko
/lib/modules/3.13.5/kernel/drivers/media/i2c/wm8775.ko
/lib/modules/3.13.5/kernel/drivers/media/i2c/cs53l32a.ko
/lib/modules/3.13.5/kernel/drivers/media/pci
/lib/modules/3.13.5/kernel/drivers/media/pci/ttpci
/lib/modules/3.13.5/kernel/drivers/media/pci/ttpci/ttpci-eeprom.ko
/lib/modules/3.13.5/kernel/drivers/media/usb
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dibusb-common.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dw2102.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-cxusb.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-friio.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-af9005.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dib0700.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dibusb-mb.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dibusb-mc.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-opera.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-gp8psk.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dtv5100.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-digitv.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-ttusb2.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-a800.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-m920x.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-cinergyT2.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-vp7045.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-vp702x.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-nova-t-usb2.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-az6027.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-technisat-usb2.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-pctv452e.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-umt-010.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dtt200u.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/b2c2
/lib/modules/3.13.5/kernel/drivers/media/usb/b2c2/b2c2-flexcop-usb.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/cx231xx
/lib/modules/3.13.5/kernel/drivers/media/usb/cx231xx/cx231xx.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/cx231xx/cx231xx-dvb.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/as102
/lib/modules/3.13.5/kernel/drivers/media/usb/as102/dvb-as102.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/siano
/lib/modules/3.13.5/kernel/drivers/media/usb/siano/smsusb.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/tm6000
/lib/modules/3.13.5/kernel/drivers/media/usb/tm6000/tm6000-dvb.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/tm6000/tm6000.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/au0828
/lib/modules/3.13.5/kernel/drivers/media/usb/au0828/au0828.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/bh_dvb_usb_v2.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/mxl111sf-tuner.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/mxl111sf-demod.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-mxl111sf.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-au6610.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-gl861.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-af9015.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-af9035.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-anysee.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-rtl28xxu.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-lmedm04.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-az6007.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb_usb_v2.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-ce6230.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-ec168.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/vuplus
/lib/modules/3.13.5/kernel/drivers/media/usb/vuplus/vuplus_tuner_turbo_driver.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/em28xx
/lib/modules/3.13.5/kernel/drivers/media/usb/em28xx/em28xx.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/em28xx/em28xx-dvb.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/videobuf-dvb.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/videobuf-vmalloc.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/bh-videodev.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/tuner.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/videobuf2-memops.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/bh-v4l2-common.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/videobuf2-vmalloc.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/v4l2-dv-timings.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/videobuf2-core.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/videobuf-core.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-core
/lib/modules/3.13.5/kernel/drivers/media/dvb-core/bh-dvb-core.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/m88ds3103.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/atbm8830.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/cxd2820r.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/ix2505v.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/ec100.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/lg2160.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/ves1x93.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/lnbp21.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/lnbp22.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/sp8870.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/mb86a16.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib8000.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/si2165.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/si2168.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/bcm3510.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/sp887x.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/isl6405.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/isl6421.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/isl6423.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/mt312.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dibx000_common.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/s921.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/itd1000.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/mt352.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda18271c2dd.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/or51132.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/or51211.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/zl10036.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/zl10039.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/l64781.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib7000m.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib7000p.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dvb-pll.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stv6110x.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda10021.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda10023.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda10048.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/au8522_dig.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda10071.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda10086.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/as102_fe.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda1004x.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stv0288.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stv0297.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stv0299.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/ds3000.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/m88rs2000.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/zl10353.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stv0367.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/si21xx.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/hd29l2.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/nxt200x.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/cx24110.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/cx24113.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/cx24116.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/cx24117.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/cx24123.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib0070.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/s5h1409.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/s5h1411.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/au8522_common.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/s5h1420.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/a8293.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib0090.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/s5h1432.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tua6100.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stb0899.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/mb86a20s.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stb6000.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/rtl2830.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/rtl2832.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/ts2020.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/ves1820.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/lgdt3305.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stb6100.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/cx22700.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/cx22702.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/af9013.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/af9033.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/lgdt330x.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib9000.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda8261.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/lgs8gl5.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stv0900.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda826x.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stv090x.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/nxt6000.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib3000mb.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib3000mc.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stv6110.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda665x.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/drxd.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/drxk.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/lgs8gxx.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners
/lib/modules/3.13.5/kernel/drivers/media/tuners/m88ts2022.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mt20xx.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/fc2580.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mxl5005s.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mxl5007t.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tda18212.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tda18218.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tda18271.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tua9001.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/xc4000.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tuner-xc2028.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tuner-simple.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/max2165.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mc44s803.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/r820t.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tea5761.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tea5767.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/e4000.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/qt1010.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/fc0011.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/fc0012.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/fc0013.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tda9887.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tuner_it913x.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mt2060.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mt2063.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tuner-types.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tda8290.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mt2131.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tda827x.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/xc5000.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mt2266.ko
/lib/modules/3.13.5/kernel/drivers/media/common
/lib/modules/3.13.5/kernel/drivers/media/common/b2c2
/lib/modules/3.13.5/kernel/drivers/media/common/b2c2/b2c2-flexcop.ko
/lib/modules/3.13.5/kernel/drivers/media/common/cx2341x.ko
/lib/modules/3.13.5/kernel/drivers/media/common/cypress_firmware.ko
/lib/modules/3.13.5/kernel/drivers/media/common/tveeprom.ko
/lib/modules/3.13.5/kernel/drivers/media/common/bh_cypress_firmware.ko
/lib/modules/3.13.5/kernel/drivers/media/common/siano
/lib/modules/3.13.5/kernel/drivers/media/common/siano/smsmdtv.ko
/lib/modules/3.13.5/kernel/drivers/media/common/siano/smsdvb.ko
/lib/modules/3.13.5/kernel/drivers/staging
/lib/modules/3.13.5/kernel/drivers/staging/rtl8712
/lib/modules/3.13.5/kernel/drivers/staging/rtl8712/r8712u.ko
/lib/modules/3.13.5/kernel/drivers/staging/winbond
/lib/modules/3.13.5/kernel/drivers/staging/winbond/w35und.ko
/lib/modules/3.13.5/kernel/drivers/staging/wlan-ng
/lib/modules/3.13.5/kernel/drivers/staging/wlan-ng/prism2_usb.ko
/lib/modules/3.13.5/modules.dep
/lib/modules/3.13.5/extra
/lib/modules/3.13.5/extra/dvb_base.ko
/lib/modules/3.13.5/extra/brcmfb.ko
/lib/modules/3.13.5/extra/fpga_directc.ko
/lib/modules/3.13.5/extra/bcm_event.ko
/lib/modules/3.13.5/extra/dvb-bcm.ko
/lib/modules/3.13.5/extra/dvb-bcm7356.ko
/lib/modules/3.13.5/extra/procmk.ko
/lib/modules/3.13.5/modules.dep.bin
/lib/modules/3.13.5/modules.devname
/lib/modules/3.13.5/modules.softdep
/lib/modules/3.13.5/modules.alias
/lib/modules/3.13.5/modules.order
/lib/modules/3.13.5/drivers
/lib/modules/3.13.5/drivers/net
/lib/modules/3.13.5/drivers/net/wireless
/lib/modules/3.13.5/drivers/net/wireless/rt5370sta.ko
/lib/modules/3.13.5/modules.alias.bin
DVB devices
/dev/dvb
/dev/dvb/adapter0
/dev/dvb/adapter0/frontend2
/dev/dvb/adapter0/audio1
/dev/dvb/adapter0/ca8
/dev/dvb/adapter0/ca7
/dev/dvb/adapter0/ca6
/dev/dvb/adapter0/ca5
/dev/dvb/adapter0/ca4
/dev/dvb/adapter0/ca3
/dev/dvb/adapter0/ca2
/dev/dvb/adapter0/ca1
/dev/dvb/adapter0/ca0
/dev/dvb/adapter0/frontend1
/dev/dvb/adapter0/frontend0
/dev/dvb/adapter0/audio0
/dev/dvb/adapter0/video1
/dev/dvb/adapter0/video0
/dev/dvb/adapter0/net8
/dev/dvb/adapter0/dvr8
/dev/dvb/adapter0/demux8
/dev/dvb/adapter0/net7
/dev/dvb/adapter0/dvr7
/dev/dvb/adapter0/demux7
/dev/dvb/adapter0/net6
/dev/dvb/adapter0/dvr6
/dev/dvb/adapter0/demux6
/dev/dvb/adapter0/net5
/dev/dvb/adapter0/dvr5
/dev/dvb/adapter0/demux5
/dev/dvb/adapter0/net4
/dev/dvb/adapter0/dvr4
/dev/dvb/adapter0/demux4
/dev/dvb/adapter0/net3
/dev/dvb/adapter0/dvr3
/dev/dvb/adapter0/demux3
/dev/dvb/adapter0/net2
/dev/dvb/adapter0/dvr2
/dev/dvb/adapter0/demux2
/dev/dvb/adapter0/net1
/dev/dvb/adapter0/dvr1
/dev/dvb/adapter0/demux1
/dev/dvb/adapter0/net0
/dev/dvb/adapter0/dvr0
/dev/dvb/adapter0/demux0
/dev/dvb/adapter1
/dev/dvb/adapter1/frontend0
/dev/dvb/adapter1/net0
/dev/dvb/adapter1/dvr0
/dev/dvb/adapter1/demux0
USBTuner revision
DVB Drivers revision
media-tree-firmware-bootcode - 0.0+git20140924-r0.11
media-tree-firmware-dspbootcode - 0.0+git20140924-r0.11
media-tree-firmware-dvb-fe-bcm3510-01 - 0.0+git20140924-r0.11
media-tree-firmware-dvb-fe-drxj-mc-1.0.8 - 0.0+git20140924-r0.11
media-tree-firmware-dvb-fe-drxj-mc-vsb-1.0.8 - 0.0+git20140924-r0.11
media-tree-firmware-dvb-fe-drxj-mc-vsb-qam-1.0.8 - 0.0+git20140924-r0.11
media-tree-firmware-dvb-fe-or51132-qam - 0.0+git20140924-r0.11
media-tree-firmware-dvb-fe-or51132-vsb - 0.0+git20140924-r0.11
media-tree-firmware-dvb-fe-or51211 - 0.0+git20140924-r0.11
media-tree-firmware-dvb-fe-xc4000-1.4.1 - 0.0+git20140924-r0.11
media-tree-firmware-dvb-fe-xc5000-1.6.114 - 0.0+git20140924-r0.11
media-tree-firmware-dvb-fe-xc5000c-4.1.30.7 - 0.0+git20140924-r0.11
media-tree-firmware-dvb-usb-avertv-a800-02 - 0.0+git20140924-r0.11
media-tree-firmware-dvb-usb-bluebird-01 - 0.0+git20140924-r0.11
media-tree-firmware-dvb-usb-dib0700-1.20 - 0.0+git20140924-r0.11
media-tree-firmware-dvb-usb-dibusb-5.0.0.11 - 0.0+git20140924-r0.11
media-tree-firmware-dvb-usb-dibusb-6.0.0.8 - 0.0+git20140924-r0.11
media-tree-firmware-dvb-usb-dtt200u-01 - 0.0+git20140924-r0.11
media-tree-firmware-dvb-usb-it9135-01 - 0.0+git20140924-r0.11
media-tree-firmware-dvb-usb-it9135-02 - 0.0+git20140924-r0.11
media-tree-firmware-dvb-usb-terratec-h5-drxk - 0.0+git20140924-r0.11
media-tree-firmware-dvb-usb-terratec-h7-az6007 - 0.0+git20140924-r0.11
media-tree-firmware-dvb-usb-terratec-h7-drxk - 0.0+git20140924-r0.11
media-tree-firmware-dvb-usb-umt-010-02 - 0.0+git20140924-r0.11
media-tree-firmware-dvb-usb-vp702x-01 - 0.0+git20140924-r0.11
media-tree-firmware-dvb-usb-vp7045-01 - 0.0+git20140924-r0.11
media-tree-firmware-dvb-usb-wt220u-01 - 0.0+git20140924-r0.11
media-tree-firmware-dvb-usb-wt220u-02 - 0.0+git20140924-r0.11
media-tree-firmware-firmware - 0.0+git20140924-r0.11
media-tree-firmware-sms1xxx-hcw-55xxx-dvbt-02 - 0.0+git20140924-r0.11
media-tree-firmware-sms1xxx-hcw-55xxx-isdbt-02 - 0.0+git20140924-r0.11
media-tree-firmware-sms1xxx-nova-a-dvbt-01 - 0.0+git20140924-r0.11
media-tree-firmware-sms1xxx-nova-b-dvbt-01 - 0.0+git20140924-r0.11
media-tree-firmware-sms1xxx-stellar-dvbt-01 - 0.0+git20140924-r0.11
media-tree-firmware-stv0672-vp4 - 0.0+git20140924-r0.11
media-tree-firmware-v4l-cx231xx-avcore-01 - 0.0+git20140924-r0.11
media-tree-firmware-v4l-cx23418-apu - 0.0+git20140924-r0.11
media-tree-firmware-v4l-cx23418-cpu - 0.0+git20140924-r0.11
media-tree-firmware-v4l-cx23418-dig - 0.0+git20140924-r0.11
media-tree-firmware-v4l-cx23885-avcore-01 - 0.0+git20140924-r0.11
media-tree-firmware-v4l-cx23885-enc-broken - 0.0+git20140924-r0.11
media-tree-firmware-v4l-cx25840 - 0.0+git20140924-r0.11
media-tree-module-a8293 - 0.0+git20140924-r0.11
media-tree-module-af9013 - 0.0+git20140924-r0.11
media-tree-module-af9033 - 0.0+git20140924-r0.11
media-tree-module-as102-fe - 0.0+git20140924-r0.11
media-tree-module-atbm8830 - 0.0+git20140924-r0.11
media-tree-module-au0828 - 0.0+git20140924-r0.11
media-tree-module-au8522-common - 0.0+git20140924-r0.11
media-tree-module-au8522-dig - 0.0+git20140924-r0.11
media-tree-module-b2c2-flexcop - 0.0+git20140924-r0.11
media-tree-module-b2c2-flexcop-usb - 0.0+git20140924-r0.11
media-tree-module-bcm3510 - 0.0+git20140924-r0.11
media-tree-module-bh-cypress-firmware - 0.0+git20140924-r0.11
media-tree-module-bh-dvb-core - 0.0+git20140924-r0.11
media-tree-module-bh-dvb-usb-v2 - 0.0+git20140924-r0.11
media-tree-module-bh-rc-core - 0.0+git20140924-r0.11
media-tree-module-bh-v4l2-common - 0.0+git20140924-r0.11
media-tree-module-bh-videodev - 0.0+git20140924-r0.11
media-tree-module-cs53l32a - 0.0+git20140924-r0.11
media-tree-module-cx22700 - 0.0+git20140924-r0.11
media-tree-module-cx22702 - 0.0+git20140924-r0.11
media-tree-module-cx231xx - 0.0+git20140924-r0.11
media-tree-module-cx231xx-dvb - 0.0+git20140924-r0.11
media-tree-module-cx2341x - 0.0+git20140924-r0.11
media-tree-module-cx24110 - 0.0+git20140924-r0.11
media-tree-module-cx24113 - 0.0+git20140924-r0.11
media-tree-module-cx24116 - 0.0+git20140924-r0.11
media-tree-module-cx24117 - 0.0+git20140924-r0.11
media-tree-module-cx24123 - 0.0+git20140924-r0.11
media-tree-module-cx25840 - 0.0+git20140924-r0.11
media-tree-module-cxd2820r - 0.0+git20140924-r0.11
media-tree-module-dib0070 - 0.0+git20140924-r0.11
media-tree-module-dib0090 - 0.0+git20140924-r0.11
media-tree-module-dib3000mb - 0.0+git20140924-r0.11
media-tree-module-dib3000mc - 0.0+git20140924-r0.11
media-tree-module-dib7000m - 0.0+git20140924-r0.11
media-tree-module-dib7000p - 0.0+git20140924-r0.11
media-tree-module-dib8000 - 0.0+git20140924-r0.11
media-tree-module-dib9000 - 0.0+git20140924-r0.11
media-tree-module-dibx000-common - 0.0+git20140924-r0.11
media-tree-module-drxd - 0.0+git20140924-r0.11
media-tree-module-drxk - 0.0+git20140924-r0.11
media-tree-module-ds3000 - 0.0+git20140924-r0.11
media-tree-module-dvb-as102 - 0.0+git20140924-r0.11
media-tree-module-dvb-pll - 0.0+git20140924-r0.11
media-tree-module-dvb-usb - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-a800 - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-af9005 - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-af9015 - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-af9035 - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-anysee - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-au6610 - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-az6007 - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-az6027 - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-ce6230 - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-cinergyt2 - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-cxusb - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-dib0700 - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-dibusb-common - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-dibusb-mb - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-dibusb-mc - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-digitv - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-dtt200u - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-dtv5100 - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-dw2102 - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-ec168 - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-friio - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-gl861 - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-gp8psk - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-lmedm04 - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-m920x - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-mxl111sf - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-nova-t-usb2 - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-opera - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-pctv452e - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-rtl28xxu - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-technisat-usb2 - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-ttusb2 - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-umt-010 - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-vp702x - 0.0+git20140924-r0.11
media-tree-module-dvb-usb-vp7045 - 0.0+git20140924-r0.11
media-tree-module-e4000 - 0.0+git20140924-r0.11
media-tree-module-ec100 - 0.0+git20140924-r0.11
media-tree-module-em28xx - 0.0+git20140924-r0.11
media-tree-module-em28xx-dvb - 0.0+git20140924-r0.11
media-tree-module-fc0011 - 0.0+git20140924-r0.11
media-tree-module-fc0012 - 0.0+git20140924-r0.11
media-tree-module-fc0013 - 0.0+git20140924-r0.11
media-tree-module-fc2580 - 0.0+git20140924-r0.11
media-tree-module-hd29l2 - 0.0+git20140924-r0.11
media-tree-module-ir-kbd-i2c - 0.0+git20140924-r0.11
media-tree-module-isl6405 - 0.0+git20140924-r0.11
media-tree-module-isl6421 - 0.0+git20140924-r0.11
media-tree-module-isl6423 - 0.0+git20140924-r0.11
media-tree-module-itd1000 - 0.0+git20140924-r0.11
media-tree-module-ix2505v - 0.0+git20140924-r0.11
media-tree-module-l64781 - 0.0+git20140924-r0.11
media-tree-module-lg2160 - 0.0+git20140924-r0.11
media-tree-module-lgdt3305 - 0.0+git20140924-r0.11
media-tree-module-lgdt330x - 0.0+git20140924-r0.11
media-tree-module-lgs8gl5 - 0.0+git20140924-r0.11
media-tree-module-lgs8gxx - 0.0+git20140924-r0.11
media-tree-module-lnbp21 - 0.0+git20140924-r0.11
media-tree-module-lnbp22 - 0.0+git20140924-r0.11
media-tree-module-m88ds3103 - 0.0+git20140924-r0.11
media-tree-module-m88rs2000 - 0.0+git20140924-r0.11
media-tree-module-m88ts2022 - 0.0+git20140924-r0.11
media-tree-module-max2165 - 0.0+git20140924-r0.11
media-tree-module-mb86a16 - 0.0+git20140924-r0.11
media-tree-module-mb86a20s - 0.0+git20140924-r0.11
media-tree-module-mc44s803 - 0.0+git20140924-r0.11
media-tree-module-msp3400 - 0.0+git20140924-r0.11
media-tree-module-mt2060 - 0.0+git20140924-r0.11
media-tree-module-mt2063 - 0.0+git20140924-r0.11
media-tree-module-mt20xx - 0.0+git20140924-r0.11
media-tree-module-mt2131 - 0.0+git20140924-r0.11
media-tree-module-mt2266 - 0.0+git20140924-r0.11
media-tree-module-mt312 - 0.0+git20140924-r0.11
media-tree-module-mt352 - 0.0+git20140924-r0.11
media-tree-module-mt9v011 - 0.0+git20140924-r0.11
media-tree-module-mxl111sf-demod - 0.0+git20140924-r0.11
media-tree-module-mxl111sf-tuner - 0.0+git20140924-r0.11
media-tree-module-mxl5005s - 0.0+git20140924-r0.11
media-tree-module-mxl5007t - 0.0+git20140924-r0.11
media-tree-module-nxt200x - 0.0+git20140924-r0.11
media-tree-module-nxt6000 - 0.0+git20140924-r0.11
media-tree-module-or51132 - 0.0+git20140924-r0.11
media-tree-module-or51211 - 0.0+git20140924-r0.11
media-tree-module-qt1010 - 0.0+git20140924-r0.11
media-tree-module-r820t - 0.0+git20140924-r0.11
media-tree-module-rtl2830 - 0.0+git20140924-r0.11
media-tree-module-rtl2832 - 0.0+git20140924-r0.11
media-tree-module-s5h1409 - 0.0+git20140924-r0.11
media-tree-module-s5h1411 - 0.0+git20140924-r0.11
media-tree-module-s5h1420 - 0.0+git20140924-r0.11
media-tree-module-s5h1432 - 0.0+git20140924-r0.11
media-tree-module-s921 - 0.0+git20140924-r0.11
media-tree-module-saa7115 - 0.0+git20140924-r0.11
media-tree-module-si2165 - 0.0+git20140924-r0.11
media-tree-module-si2168 - 0.0+git20140924-r0.11
media-tree-module-si21xx - 0.0+git20140924-r0.11
media-tree-module-smsdvb - 0.0+git20140924-r0.11
media-tree-module-smsmdtv - 0.0+git20140924-r0.11
media-tree-module-smsusb - 0.0+git20140924-r0.11
media-tree-module-sp8870 - 0.0+git20140924-r0.11
media-tree-module-sp887x - 0.0+git20140924-r0.11
media-tree-module-stb0899 - 0.0+git20140924-r0.11
media-tree-module-stb6000 - 0.0+git20140924-r0.11
media-tree-module-stb6100 - 0.0+git20140924-r0.11
media-tree-module-stv0288 - 0.0+git20140924-r0.11
media-tree-module-stv0297 - 0.0+git20140924-r0.11
media-tree-module-stv0299 - 0.0+git20140924-r0.11
media-tree-module-stv0367 - 0.0+git20140924-r0.11
media-tree-module-stv0900 - 0.0+git20140924-r0.11
media-tree-module-stv090x - 0.0+git20140924-r0.11
media-tree-module-stv6110 - 0.0+git20140924-r0.11
media-tree-module-stv6110x - 0.0+git20140924-r0.11
media-tree-module-tda10021 - 0.0+git20140924-r0.11
media-tree-module-tda10023 - 0.0+git20140924-r0.11
media-tree-module-tda10048 - 0.0+git20140924-r0.11
media-tree-module-tda1004x - 0.0+git20140924-r0.11
media-tree-module-tda10071 - 0.0+git20140924-r0.11
media-tree-module-tda10086 - 0.0+git20140924-r0.11
media-tree-module-tda18212 - 0.0+git20140924-r0.11
media-tree-module-tda18218 - 0.0+git20140924-r0.11
media-tree-module-tda18271 - 0.0+git20140924-r0.11
media-tree-module-tda18271c2dd - 0.0+git20140924-r0.11
media-tree-module-tda665x - 0.0+git20140924-r0.11
media-tree-module-tda8261 - 0.0+git20140924-r0.11
media-tree-module-tda826x - 0.0+git20140924-r0.11
media-tree-module-tda827x - 0.0+git20140924-r0.11
media-tree-module-tda8290 - 0.0+git20140924-r0.11
media-tree-module-tda9887 - 0.0+git20140924-r0.11
media-tree-module-tea5761 - 0.0+git20140924-r0.11
media-tree-module-tea5767 - 0.0+git20140924-r0.11
media-tree-module-tm6000 - 0.0+git20140924-r0.11
media-tree-module-tm6000-dvb - 0.0+git20140924-r0.11
media-tree-module-ts2020 - 0.0+git20140924-r0.11
media-tree-module-ttpci-eeprom - 0.0+git20140924-r0.11
media-tree-module-tua6100 - 0.0+git20140924-r0.11
media-tree-module-tua9001 - 0.0+git20140924-r0.11
media-tree-module-tuner - 0.0+git20140924-r0.11
media-tree-module-tuner-it913x - 0.0+git20140924-r0.11
media-tree-module-tuner-simple - 0.0+git20140924-r0.11
media-tree-module-tuner-types - 0.0+git20140924-r0.11
media-tree-module-tuner-xc2028 - 0.0+git20140924-r0.11
media-tree-module-tveeprom - 0.0+git20140924-r0.11
media-tree-module-tvp5150 - 0.0+git20140924-r0.11
media-tree-module-v4l2-dv-timings - 0.0+git20140924-r0.11
media-tree-module-ves1820 - 0.0+git20140924-r0.11
media-tree-module-ves1x93 - 0.0+git20140924-r0.11
media-tree-module-videobuf-core - 0.0+git20140924-r0.11
media-tree-module-videobuf-dvb - 0.0+git20140924-r0.11
media-tree-module-videobuf-vmalloc - 0.0+git20140924-r0.11
media-tree-module-videobuf2-core - 0.0+git20140924-r0.11
media-tree-module-videobuf2-memops - 0.0+git20140924-r0.11
media-tree-module-videobuf2-vmalloc - 0.0+git20140924-r0.11
media-tree-module-wm8775 - 0.0+git20140924-r0.11
media-tree-module-xc4000 - 0.0+git20140924-r0.11
media-tree-module-xc5000 - 0.0+git20140924-r0.11
media-tree-module-zl10036 - 0.0+git20140924-r0.11
media-tree-module-zl10039 - 0.0+git20140924-r0.11
media-tree-module-zl10353 - 0.0+git20140924-r0.11
Vu+ Kernel Drivers
-rw-r--r-- 1 root root 7872 Dec 1 20:17 /lib/modules/3.13.5/extra/bcm_event.ko
-rw-r--r-- 1 root root 5780 Dec 1 20:17 /lib/modules/3.13.5/extra/brcmfb.ko
lrwxrwxrwx 1 root root 40 Nov 30 22:53 /lib/modules/3.13.5/extra/dvb-bcm.ko -> /lib/modules/3.13.5/extra/dvb-bcm7356.ko
-rw-r--r-- 1 root root 1306220 Dec 1 20:17 /lib/modules/3.13.5/extra/dvb-bcm7356.ko
-rw-r--r-- 1 root root 6549904 Dec 1 20:17 /lib/modules/3.13.5/extra/dvb_base.ko
-rw-r--r-- 1 root root 2376 Dec 1 20:17 /lib/modules/3.13.5/extra/fpga_directc.ko
-rw-r--r-- 1 root root 4412 Dec 1 20:17 /lib/modules/3.13.5/extra/procmk.ko
Box Info
USB devices
Kernel Messages
sda: sda1
ALSA device list:
UBIFS: parse sync
devtmpfs: mounted
Use it with care.
Use it with care.
procmk_init
[GP]:brcm_pwm_init
[LCD]: registered
0:0
FE tune
[AUD]: Mute : 0
[AUD]: Mute : 0
[AUD]: AUDIO_STOP 0
FE tune
[AUD]: Mute : 0
[AUD]: Mute : 0
[AUD]: AUDIO_STOP 0
[AUD]: Mute : 0
[AUD]: AUDIO_STOP 0
[AUD]: Mute : 0
[AUD]: AUDIO_STOP 0
[AUD]: Mute : 0
[AUD]: AUDIO_STOP 0
FE tune
[AUD]: Mute : 0
[AUD]: Mute : 0
NIM Sockets
NIM Socket 0:
Type: DVB-S2
Frontend_Device: 0
NIM Socket 1:
Type: DVB-S2
Frontend_Device: 1
NIM Socket 2:
Type: DVB-T
end
Frontend_Device: 2
Modules Loaded
Module Size Used by
ipv6 332460 34
brcmfb 1590 4
ext2 57304 0
dib7000p 30631 1
Kernel Objects
/lib/modules/3.13.5
DVB devices
/dev/dvb
/dev/dvb/adapter0
/dev/dvb/adapter1
USBTuner revision
Vu+ Kernel Drivers
Box Info
USB devices
Kernel Messages
sda: sda1
ALSA device list:
UBIFS: parse sync
devtmpfs: mounted
Use it with care.
Use it with care.
procmk_init
[GP]:brcm_pwm_init
[LCD]: registered
0:0
FE tune
[AUD]: Mute : 0
[AUD]: Mute : 0
[AUD]: AUDIO_STOP 0
FE tune
[AUD]: Mute : 0
[AUD]: Mute : 0
[AUD]: AUDIO_STOP 0
[AUD]: Mute : 0
[AUD]: AUDIO_STOP 0
[AUD]: Mute : 0
[AUD]: AUDIO_STOP 0
[AUD]: Mute : 0
[AUD]: AUDIO_STOP 0
FE tune
[AUD]: Mute : 0
[AUD]: Mute : 0
NIM Sockets
NIM Socket 0:
Type: DVB-S2
Frontend_Device: 0
NIM Socket 1:
Type: DVB-S2
Frontend_Device: 1
NIM Socket 2:
Type: DVB-T
end
Frontend_Device: 2
Modules Loaded
Module Size Used by
ipv6 332460 34
brcmfb 1590 4
ext2 57304 0
dib7000p 30631 1
Kernel Objects
/lib/modules/3.13.5
DVB devices
/dev/dvb
/dev/dvb/adapter0
/dev/dvb/adapter1
USBTuner revision
Vu+ Kernel Drivers
Hi again, angelofsky1980 did you manage to verify anything from this log mate?
Is there something i can do to fix it?For the rest of the use 3.0.1F version is perfect.
No problems at all.Thanks for the support.
ps. sorry for posting all this 3 times, i had internet problems that day
In case can you post the file here so i download it and insert it via ftp or winscp to the vusolo2?
As a temporary solution i mean before waiting for the updates?
Thank you.
Okay, waiting for new updates i did this at my linux computer :
# In order to use, you need to:
# 1) Download the windows driver with something like:
# wget http://www.steventoth.net/linux/xc5000/HVR-12x0-14x0-17x0_1_25_25271_WHQL.zip
# ( find here: http://cdn.pinnaclesys.com/SupportFiles/PCTV Drivers/ReadmePCTV.htm )
# 2) Extract the file hcw85bda.sys from the zip into the current dir:
# unzip -j HVR-12x0-14x0-17x0_1_25_25271_WHQL.zip Driver85/hcw85bda.sys
# 3) Download the extract script
# wget http://linuxtv.org/hg/v4l-dvb/raw-f...x/Documentation/video4linux/extract_xc3028.pl
# 3) run the script:
# perl extract_xc3028.pl
# 4) copy the generated file:
# sudo cp xc3028-v27.fw /lib/firmware
then coppied the created file into the receiver and now finaly the tuner works.
regards.
