BlackHole 3.0.4 -> 3.0.9
barbatrukko
Hi,
I have VuDuo2 and old 3.0.4 BH and now would switch to lastest.
I read in 3.0.9 note this :
** *Limitation : TS is broken when both tuners are in use, if one tuner is configured as DVB-C and the other is configured as DVB-T2.
Is it still present also in later versions (3.0.9.L)? Does that mean I can't record Cable and TV simultaneously?
Becouse I don't have cable but sometime I can register SAT and TV simultaneously.
If I create Complete Backup, if I have problem with 3.0.9, what I ned for restore old version?
1) SAT vs Terrestrial is a completely different thing than Cable vs DVB-T! DVB-C and DVB-T use the SAME tuner, sat and "not SAT" don't!
How there can be an issue for two physically different tuners?
2) You should always make FullBackups, not only before installing a new image or releases.
I have it automatically scheduled every day, because in OBH is easy to do by an image function itself. In BH I used the plugin Automatic Full Backup, made by the same author of the OBH F.B. module.
