BlackHole 3.1.0 Multistream Vu+ Ultimo4K
Ev0
Admin
BlackHole 3.1.0 Multistream​
What is new ?
  • Add Duo4K SE Support
  • Various bug fixed and tweaks in the background
1-png.49348
2-jpg.49364
4-jpg.49350
5-jpg.49351
6-jpg.49352
7-png.49353
8-jpg.49354
9-jpg.49355
10-jpg.49356
11-jpg.49357
12-jpg.49358
This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- CrossEPG supported
- EPG Import supported
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
ServiceApp and Exteplayer3 are both external plugins, and are not part of the BH image, therefore any users that do not want / need to use these plugins, can remove them via the BH SpeedUp panel.
Credits:
Thanks to MX3L for ServiceApp https://github.com/mx3L/serviceapp/tree/develop
Thanks to SamSamSam for Exteplayer3 https://github.com/e2iplayer/exteplayer3
Thanks to dpeddi for patching ServiceApp and Exteplayer3 to work on BH.
Thanks to Pedro_Newbie for Backup script.
DISCLAIMER
LICENSE (TERM OF USE)
DOWNLOAD HERE:​
What is new ?
1-png.49348
2-jpg.49364
4-jpg.49350
5-jpg.49351
6-jpg.49352
7-png.49353
8-jpg.49354
9-jpg.49355
10-jpg.49356
11-jpg.49357
12-jpg.49358
Addons
Infobar / OSD
Analog Clock Gui
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
UPnP Client Djmount
Pcsc Panel
Tuner Server
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits:
DISCLAIMER
Hi. Thanks for fresh firmware. Bug on Vu+ Ultimo 4k. If i set 2160p resolution display starts looks in pink color. Reboot not help. only decrease resolution to 1080p or set RGB colorspace.
Also options "Scaler vertical dejagging" and "Smooth" call bugs/artifacts on some channels in 2160p resolution with RGB colorspace.
The problem is your TV or HDMI cable not the box.
You need to change the HDMI Colorspace and possibly also the HDMI colordepth
Cable is high quality(im use same cable for other 4k devices like PS4 PRO and all fine), and i never seen this trouble for all time when im use this receiver on any firmware releases. If i seen pink screen after flashing fresh firmware and set 2160p and never seen this before, i think its not cable. Its looks like "video driver" in firmware is broken.
Well seeing as NOTHING has changed between 3.0.9 and 3.1.0 for the Ultimo4K and that I am using an Ultimo4K myself the problem is not the image.
Ev0 dont know why but i cannot repeat this bug. Im install some addons, at this moment pink screen fixed. But i got other problem, possibly maybe its not receiver. Fashion 4k channel not work from both providers, i heard only sound. Other 4k channels works fine. Yes if i try seen this channel via VLC from this receiver i can seen picture. Please check this channel if possible. This problem was on 3.0.9 too. Spmetimes this channel works sometimes not.
I think the problem is the channel transmitter, not the black hole image
Use the time shift button and if the problem is solved with the time shift button, it is definitely the problem of the sender.
I have updated to this image on my Ultimo 4k box. Everything is working fine. But my drivers are not upto date like in the picture on here. In the picture it says 20200903.r0 my drivers show as 20190424.r0. Is this normal or should I be updating another way?
meekey.
meekey.
It is correct, the picture is from Duo4K SE
I have done a reinstall of Black Hole 3.1.
Before reinstallation, the box controlled so that the TV selected the correct HDMI input automatically.
Can't remember where the setting was for this.
Tried to install OpenBh 5.3 together with various softcams.
Nothing works.
Black Hole 3.1 and softcams work immediately.
