BlackHole 3.1.0 Multistream Vu+ Zero4K
Ev0
Admin
What is new ?
  • Add Duo4K SE Support
  • Various bug fixed and tweaks in the background
This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- CrossEPG supported
- EPG Import supported
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
ServiceApp and Exteplayer3 are both external plugins, and are not part of the BH image, therefore any users that do not want / need to use these plugins, can remove them via the BH SpeedUp panel.
Credits:
Thanks to MX3L for ServiceApp https://github.com/mx3L/serviceapp/tree/develop
Thanks to SamSamSam for Exteplayer3 https://github.com/e2iplayer/exteplayer3
Thanks to dpeddi for patching ServiceApp and Exteplayer3 to work on BH.
Thanks to Pedro_Newbie for Backup script.
DISCLAIMER
LICENSE (TERM OF USE)
DOWNLOAD HERE:
macada
Good morning .... will the update to version 3.1.0 be updated via system update from the VU + menu? I have version 3.0.9 and I would like to be able to keep everything I have and be able to go to 3.1.0. without having to flash.
Also this version 3.1.0. It has been removed because the new VU + DUO model will be released on the 15th of this month
Is it possible that you put the update via update of the system please?
Ev0
Admin
It is a full flash update only.
AlexWilMac
Moderator
Please: post useful messages. What does it mean your message? Every images' download links are perfectly working. Aren't you able to download or what? The less clear an issue, the less answers you'll get in return.
If you have downloading issues it is surely not due to our forum. Otherwise, please, explain.
buffdadi
After installing the latest version of this image 3.1 in my VU SOLO 4K device ; no longer recognizes the smart card ; which was working normally on previos updates thank you
