BlackHole and streaming
fuser
I enjoy always trying new things, so I wanted to see if it was possible to play a video and audio stream produced with vlc from a pc on the vu + duo.
I can say that I managed with the openpli4.0, even if the film is not finished in the loop created with vlc on the PC, on the last black hole, however, you hear the audio, but you can not see anything.
I also tried the StramTvPlayer plugin adding the link to stream.xml, the same result is heard but not seen
I wanted to ask if you need to set something or something else to do.
Tanks
fuser
