Blackhole does not update
meekey
I have Blackhole 3.0.9.H on my Vu Ultimo 4k. The info bar always shows there`s an online update available when there isn`t. This week I saw on here, that 3.0.9.I, was available. So I went through the online update when finished, it said 2 packages had been installed, but the image still shows as 3.0.9 H and the info bar still shows there`s an online update available. But nothing changes.
meekey.
root@vuuno4kse:~# opkg update
Downloading http://feeds.vuplus-community.net/3rd-party-settings/Packages.gz.
Inflating http://feeds.vuplus-community.net/3rd-party-settings/Packages.gz.
Updated list of available packages in /var/lib/opkg/official-3rd-party-settings.
Downloading http://feeds.vuplus-community.net/3.0.9/vuuno4kse/all/Packages.gz.
Inflating http://feeds.vuplus-community.net/3.0.9/vuuno4kse/all/Packages.gz.
Updated list of available packages in /var/lib/opkg/official-all.
Downloading http://feeds.vuplus-community.net/3.0.9/vuuno4kse/armv7ahf-vfp-neon/Packages.gz.
Inflating http://feeds.vuplus-community.net/3.0.9/vuuno4kse/armv7ahf-vfp-neon/Packages.gz.
Updated list of available packages in /var/lib/opkg/official-armv7ahf-vfp-neon.
Downloading http://feeds.vuplus-community.net/3.0.9/vuuno4kse/vuuno4kse/Packages.gz.
Inflating http://feeds.vuplus-community.net/3.0.9/vuuno4kse/vuuno4kse/Packages.gz.
Updated list of available packages in /var/lib/opkg/official-vuuno4kse.
root@vuuno4kse:~#
not possible plase first
opkg list_upgradable
and report
and then opkg upggrade
and report.
root@vuuno4kse:~#
root@vuuno4kse:~#
root@vuuno4kse:~# opkg list_upgradable
root@vuuno4kse:~#
root@vuuno4kse:~# opkg upgrade
root@vuuno4kse:~#
had seen an update notice, I have the H version,
I have updated and always see H version, on this forum I see that the "I" version is available, but I do not have this update, and it is not updated. it will be nice for you, I really don't care how death was, but I would be curious ...
I did the opkg list_upgradable and I get the message " Not selecting python ~ requests 2.9.2 as installing it would break existing dependencies". I still see the "Online Update Available" on the info bar but does not change from H to I
Now it shows " Not selecting python ~ requests 2.9.2 as installing it would break existing dependencies" and "Package python requests ( 2. 12. 4-r0 ) installed in root is up to date"
the same on Duo2 (remains on BH3.0.9.H)
(i think i have the most from .I , but the info is showing .H)
What i did was…..
While i was on .H (Before the .I was released)
Shortly before the .I was released (hours/minutes before), I looked for updates and there was 30+/40+ packages to update.
Then the .I was released.
I updated again and there was 2 packages to update.
But info was/is still showing BH3.0.9.H
Best regards
Which are the two packages? If you want to know them, use telnet and give the command
opkg update && opkg upgrade
And, above all: it's your image installed in flash or in multiboot? Because usually the two components not updatable are the openmultiboot ones if you try to update the image in multiboot: it can't be done because they are already running.
Otherwise, copy and paste the telnet output to that command.
