This might be a stupid question but is the blackhole epg that comes with the image the same as cross epg.
If not any info would be great ...
Thanks
Hi sorry I have the blackhole epg working fine but I was not sure if they were the same thing
Hi, is there any chance to remove CrossEPG from BH ? I mean from main Setup menu. I don't need CrossEPG.
Yesbut is there any chance to remove it from setup menu ?
I know that i don't save the space, but i don't want to have some plugins in the setup which i don't need.
So i how can i remove it ? If i remove enigma2-plugin-systemplugins-crossepg than will be removed from menu ?
I know it's off topic, but how can i remove entry from Setup menu ?
