BlackHole Online Update, problem
pepanzeman
Hi. Do not know why I can not online upgrade my Black Hole image automatically? The following are always displayed: Done - Installed or upgraded 0 packages. But I have the old BlackHole 3.0.3.Q. I have Google DNS in my network settings: 8.8.8.8. Thank you for your help.
You can't UPGRADE a image by an online UPDATE. An update is for the same version; an upgrade, as the word says, is a change to an upper version.
To 3.0.3Q was probably the last update of 303.
If you want a newer image, you need to reflash it, in case saving your settings (channels).
P.S. And, anyway, you are OT here because this is the OpenBlackHole section of the forum.
*** Thread moved to BlackHole section, i.e, the correct section ) ***
