Blackhole Solo 2 & Blindscan
brummie
does anyone know if blindscan will work with the solo 2, it works well on my uno and would be great for the solo 2 if we can get it to work, i have added it but it wont scan and says no transponders found.
Are you blindscanning the Ku band on Tuner "A"?
I have the Duo2 here in the U.S. This receiver should be similar to yours. The Duo2 blindscan does not work at all on C band. It also does not work on the Ku band except for tuner "A".
As far as I know blindscan doesn't work on solo2, think its a hardware limitation but hope they are still trying to solve this.
Sent from my HTC Sensation Z710e using Tapatalk 2
