Blackhole Spinner
dibsta
Hi all i seem to be having issues when im watching tv the blackhole spinner comes on for anything between 30 sec to a couple of minutes. When this happens i cant do anything with remote
Can anyone point me in the right direction to sort
David
David
What box have you got? Have you enabled a swap file sounds like your ram could be pretty full if you have a duo or similar.
Also use black hole speed up to disable things you don't use as this can increase performance
