Blackhole VU+ Duo crashes everywhere
OK.
I reinstalled the same image, reconfigured the hdd etc and all seems to be working and like a charm - yippeeeeee.....
My only trouble is I want to change some of the remote navigation / way buttons work. Anyway how I can do that? Is it simple?
Thanks for all your help.
You can use MultiQuickButton o PauliKeymap (or something else). You can download these plugins from BH Addon Server.
Hi everybody,
after many years of use of VIX image on my Duo I'M trying back Black Hole.
Since the menu are really different I'm unable to find the log manager. Where is it?
Hi Angelo
I think it´s a plugin that send crashlog´s file on VIX Images. On blackhole, when the crash occurs, the file goes to /tmp ( flash memory ), root of /media/usb, or /media/hdd root.
Into BH the crashlog is placed into /hdd foer as usual.
The log manager let you set the output location for both crash and debug logs.
Also you can have a look at logs right from the receiver.
Where is supposed to go the debug log?
Ah ok ... Into BH image there is no setup for this kind of things. The usual and default location is keep (/hdd for crashlogs, /var/log for everything else related to OS)
